SWR201-NREN-S10-SA-WH
    SULLINS
    CONN HDR 2MM TIN 10POS
SWR201-NREN-S10-SA-WH 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2003 INITIAL RELEASE 7/17/2009 JH F F E E 2.00±0.10 .079±.004 A±0.20[.008] 4.70±0.25 .185±.010 SWR201-NREN-S_ _-SB-WH SWR201-NREN-S_ _-SA-WH 1.80±0.20 .071±.008 B±0.25[.010] D D A±0.10[.004] 2.00±0.05 .079±.002 6.10±0.20 .240±.008 +0.10 +.004 0.70 .028 0.00 - .000 RECOMMENDED PCB LAYOUT C C 3.40±0.20 .134±.008 CIRCUIT 1 0.80±0.20 .031±.008 P/N: SWR201-NREN-S_ _-SA-WH 4.70±0.25 .185±.010 1.80±0.20 .071±.008 0.50 .020 B A B NOTES: 1. INSULATOR MATERIAL: NYLON66, UL94V-0, COLOR:WHITE. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: TIN OVERALL. 4. CURRENT RATING: 2 AMPS. 5. VOLTAGE RATING: 100V AC/DC. 3.40±0.20 .134±.008 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 10 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING VOLTAGE: 800V AC. 9. OPERATING TEMPERATURE: -25° C TO +85° C. P/N: SWR201-NREN-S_ _-SB-WH 10. MATES WITH SWH201 SERIES SINGLE ROW HOUSING. 8 7 6 5 UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 5 .X= .3 [.01] .XX= .15 [.006] .XXX= .050 [.0020] SURFACE FINISH: 63 Ra DRAWN 4 9/03/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. A SWR201-NREN-S_ _-S_-WH SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 NAME WAFER, 2mm CC 1 ROW REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT DATE REV 11298 SCALE: 10:1 2 A SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\JH TEMP\11298, SWR201-NREN-S_ _-S_-WH PRINT: 9/25/2009
SWR201-NREN-S10-SA-WH 价格&库存
很抱歉,暂时无法提供与“SWR201-NREN-S10-SA-WH”相匹配的价格&库存,您可以联系我们找货
