SWR201-NRPN-S03-HM-BG
    SULLINS
    CONN HDR 2MM GOLD 3POS SMD R/A
SWR201-NRPN-S03-HM-BG 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2003 INITIAL RELEASE 7/17/2009 JH F F 3.40 .134 5.70 .224 E E 1.50 .059 9.20 .362 1.00±0.05 .039±.002 CIRCUIT 1 2.00±0.10 .079±.004 D 2.00±0.05 .079±.002 A 1.60 .063 D RECOMMENDED PCB LAYOUT TOLERANCE: 0.10mm [.004"] A±0.20[.008] 5.50±0.25 .217±.010 B±0.25[.010] 2.43±0.20 .096±.008 C C 6.00±0.20 .236±.008 7.65±0.25 .301±.010 0.50 .020 1.00±0.20 .039±.008 B A NOTES: 1. INSULATOR MATERIAL: NYLON6T, UL94V-0, COLOR:BEIGE. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: GOLD FLASH OVERALL. 4. CURRENT RATING: 2 AMPS. 5. VOLTAGE RATING: 100V AC/DC. 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 10 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING VOLTAGE: 800V AC. 9. OPERATING TEMPERATURE: -25° C TO +85° C. 10. MATES WITH SWH201 SERIES SINGLE ROW HOUSING. 8 7 6 B UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 5 .X= .3 [.01] .XX= .15 [.006] .XXX= .050 [.0020] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 9/04/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. A WAFER , 2mm CC, 1 ROW, HM SWR201-NRPN-S_ _-HM-BG SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 11302 SCALE: 10:1 2 A SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\2003, wafer 201 series\11302, SWR201-NRPN-S_ _-HM-BG PRINT: 9/24/2009
SWR201-NRPN-S03-HM-BG 价格&库存
很抱歉,暂时无法提供与“SWR201-NRPN-S03-HM-BG”相匹配的价格&库存,您可以联系我们找货
