SWR204-NREN-D05-RA-GA
    SULLINS
    CONN HDR DUAL 2MM TIN 10POS R/A
SWR204-NREN-D05-RA-GA 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 1994 INITIAL RELEASE 7/17/2009 JH F F A±0.10[.004] 0.50 .020 2.00±0.05 .079±.002 E E CIRCUIT 2 2.00±0.05 .079±.002 2.00±0.10 .079±.004 2.00±0.10 .079±.004 +0.10 +.004 0.70 .028 0.00 - .000 CIRCUIT 1 RECOMMENDED PCB LAYOUT A±0.20[.008] D D 5.00±0.25 .197±.010 B±0.25[.010] C C 7.00±0.20 .276±.008 2.00±0.15 .079±.006 6.50±0.25 .256±.010 9.50±0.25 .374±.010 B B 3.00±0.20 .118±.008 A NOTES: 1. INSULATOR MATERIAL: NYLON66, UL94V-0, COLOR:GREY (PANTONE 7528C). 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: TIN OVERALL. 4. CURRENT RATING: 3 AMPS. 5. VOLTAGE RATING: 250V AC/DC. 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 10 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING VOLTAGE: 800V AC. 9. OPERATING TEMPERATURE: -25° C TO +85° C. 10. MATES WITH SWH204 SERIES DUAL ROW HOUSING. 8 7 6 5 UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 5 .X= .3 [.01] .XX= .15 [.006] .XXX= .050 [.0020] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 4 DRAWN NAME 7/17/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. WAFER, 2mm CC, DUAL ROW, RA SWR204-NREN-D_ _-RA-GA SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 11286 SCALE: 5:1 2 A SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\1994, wafer 204 series\11286, SWR204-NREN-D_ _-RA-GA PRINT: 9/15/2009 A
SWR204-NREN-D05-RA-GA 价格&库存
很抱歉,暂时无法提供与“SWR204-NREN-D05-RA-GA”相匹配的价格&库存,您可以联系我们找货
