SWR25A-NREC-S03-ST-BR
    SULLINS
    CONN HDR 2.54MM TIN 3POS
SWR25A-NREC-S03-ST-BR 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2006 INITIAL RELEASE 9/17/09 JH F F A±0.10[.004] Circuit 1 2.54±0.10 .100±.004 E E 1.02±0.05 .040±.002 P.C.B LAYOUT 2.54±0.10 .100±.004 A±0.20 .008 D D 6.35±0.25 .250±.010 3.25±0.20 .128±.008 B±0.25 .010 8.18±0.25 .322±.010 C C 14.20±0.20 .559±.008 3.18±0.20 .125±.008 3.40±0.20 .134±.008 B B 0.64 .025 A NOTES: 1. INSULATOR MATERIAL: NYLON66, UL94V-2, COLOR: DARK RED (PANTONE 1685C). 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: TIN OVERALL. 4. CURRENT RATING: 4 AMPS. 5. VOLTAGE RATING: 250V AC/DC. 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 10 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING VOLTAGE: 1000V AC. 9. OPERATING TEMPERATURE: -25° C TO +85° C. 10. MATES WITH SWH25A SERIES SINGLE ROW HOUSING. 8 7 6 5 UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 5 .X= .3 [.01] .XX= .15 [.006] .XXX= .050 [.0020] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 4 DATE DRAWN NAME JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. WAFER 2.54mm CC, 1 ROW ST SWR25A-NREC-S_ _-ST-BR SIZE DWG. NO. REV C 11316 INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 9/16/09 A SCALE: 7:1 2 SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\2006, wafer 25_ series\11316, SWR25A-NREC-S_ _-ST-BR PRINT: 9/29/2009 A
SWR25A-NREC-S03-ST-BR 价格&库存
很抱歉,暂时无法提供与“SWR25A-NREC-S03-ST-BR”相匹配的价格&库存,您可以联系我们找货
