SWR25C-NREC-S04-ST-WH-M42
    SULLINS
    CONN HDR 2.54MM TIN 4POS
SWR25C-NREC-S04-ST-WH-M42 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2006 INITIAL RELEASE 9/17/09 JH F F 7.62±0.10 .300±.004 2.54±0.10 .100±.004 E E 2.19±0.05 .086±.002 1.02±0.05 .040±.002 Circuit 1 1.10±0.05 .043±.002 P.C.B LAYOUT 2.54±0.10 .100±.004 7.62±0.20 .30±.01 D D 5.80±0.25 .228±.010 10.16±0.25 .400±.010 2.54±0.20 .100±.008 C C 8.00±0.25 .315±.010 13.50±0.20 .531±.008 2.50±0.20 .098±.008 1.40±0.10 .055±.004 0.80±0.10 .031±.004 0.64 .025 B A 3.50±0.20 .138±.008 B NOTES: 1. INSULATOR MATERIAL: NYLON66, UL94V-0, COLOR: WHITE. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: TIN OVERALL. 4. CURRENT RATING: 4 AMPS. 5. VOLTAGE RATING: 250V AC/DC. 6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 10 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING VOLTAGE: 1000V AC. 9. OPERATING TEMPERATURE: -25° C TO +85° C. 10. MATES WITH SWH25C SERIES SINGLE ROW HOUSING. 11. MODIFICATION: POST AT POSITION 3. 8 7 6 UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 5 .X= .3 [.01] .XX= .15 [.006] .XXX= .050 [.0020] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DATE DRAWN THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. A WAFER 2.54mm CC, 1 ROW SWR25C-NREC-S04-ST-WH-M42 SIZE DWG. NO. REV C 11322 INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 NAME 9/17/09 JH A SCALE: 6:1 2 SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\2006, wafer 25_ series\11322, SWR25C-NREC-S04-ST-WH-M42 PRINT: 9/29/2009
SWR25C-NREC-S04-ST-WH-M42 价格&库存
很抱歉,暂时无法提供与“SWR25C-NREC-S04-ST-WH-M42”相匹配的价格&库存,您可以联系我们找货
