8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2268
INITIAL RELEASE
03/21/2011
LH
B
2422
ADD 'P' PLATING OPTION
08/09/2011
GC
F
F
E
E
B .012[ 0.30]
.197 5.00
D
D
.100 2.54
A
HEAD DIM.
C
TAIL DIM. .012[0.30]
.158 4.02
C
.098 2.50
.100 2.54
A
.100 2.54
.025 0.64
.100 2.54
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK.
2. CONTACT MATERIAL: SEE PAART NUMBER CODING.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS PER CONTACT.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 1000 VAC.
8. OPERATING TEMPERATURE: SEE PART NUMBER CODING.
9. *PROCESSING TEMP.: SEE PART NUMBER CODING.
B
.100 2.54
RECOMMENDED PCB LAYOUT
DRAWN
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING
TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB,
AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES: ANGULAR:
.XX= .012 [.30]
.XXX= .008 [.20]
.XXXX= .0040 [.100]
RoHS COMPLIANT
8
7
6
.039 1.00
5
4
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
03/21/2011 LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER .100"[2.54mm]PITCH, 2 ROWS, RA
PART NUMBER
SIZE
C
_ R _C_ _ _-D_ _N-M71RC
CAGE CODE
54453
SCALE: 4:1
2
DWG. NO.
11639
SHEET 1 OF 1
1
REV
B
FILE NAME: Z:\ECO PENDING\2422, TAIWAN HEADER 100 CC ADD P PLATING\11639, _ R_C_ _ _D_ _N-M71RC PRINT: 8/26/2011
A
很抱歉,暂时无法提供与“PREC023DGAN-M71RC”相匹配的价格&库存,您可以联系我们找货
