PRPC017DGAN-M71RC
PRPC017DGAN-M71RC
    SULLINS
    CONN HEADER .100" DUAL R/A 34POS
PRPC017DGAN-M71RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2268 INITIAL RELEASE 03/21/2011 LH B 2422 ADD 'P' PLATING OPTION 08/09/2011 GC F F E E B .012[ 0.30] .197 5.00 D D .100 2.54 A HEAD DIM. C TAIL DIM. .012[0.30] .158 4.02 C .098 2.50 .100 2.54 A .100 2.54 .025 0.64 .100 2.54 B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK. 2. CONTACT MATERIAL: SEE PAART NUMBER CODING. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 3 AMPS PER CONTACT. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: 1000 VAC. 8. OPERATING TEMPERATURE: SEE PART NUMBER CODING. 9. *PROCESSING TEMP.: SEE PART NUMBER CODING. B .100 2.54 RECOMMENDED PCB LAYOUT DRAWN *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: ANGULAR: .XX= .012 [.30] .XXX= .008 [.20] .XXXX= .0040 [.100] RoHS COMPLIANT 8 7 6 .039 1.00 5 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 03/21/2011 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER .100"[2.54mm]PITCH, 2 ROWS, RA PART NUMBER SIZE C _ R _C_ _ _-D_ _N-M71RC CAGE CODE 54453 SCALE: 4:1 2 DWG. NO. 11639 SHEET 1 OF 1 1 REV B FILE NAME: Z:\ECO PENDING\2422, TAIWAN HEADER 100 CC ADD P PLATING\11639, _ R_C_ _ _D_ _N-M71RC PRINT: 8/26/2011 A
PRPC017DGAN-M71RC
1. 物料型号:N-M71RC 2. 引脚分配:文档提供了不同型号的引脚分配,例如C002D、C003D等,以及它们的尺寸和引脚数量。 3. 参数特性: - 绝缘材料:UL 94V-0,黑色 - 接触材料:见型号编码 - 接触镀层:见型号编码 - 推荐PCB布局:符合RoHS标准 - 电流额定值:每个接触3安培 - 绝缘电阻:最小5000兆欧姆 - 接触电阻:最大20毫欧姆 - 耐电压:1000 VAC - 工作温度:见型号编码 - 加工温度:见型号编码 4. 功能详解:文档中没有提供详细的功能解释,但根据参数特性可以推断该物料是用于电气连接的连接器。 5. 应用信息:文档没有明确指出应用信息,但根据其电气特性和尺寸,可能用于需要电气连接的多种应用。 6. 封装信息:提供了不同型号的封装尺寸,例如C002D、C003D等,以及它们的具体尺寸。
PRPC017DGAN-M71RC 价格&库存
很抱歉,暂时无法提供与“PRPC017DGAN-M71RC”相匹配的价格&库存,您可以联系我们找货
