PREC015SBDN-M71RC
PREC015SBDN-M71RC
    SULLINS
    CONN HEADER .100" SNGL R/A 15POS
PREC015SBDN-M71RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2268 INITIAL RELEASE 03/21/2011 LH B 2422 ADD 'P' PLATING OPTION 08/08/2011 GC F F E E B .012[ 0.30] .098 2.50 A TAIL DIM. .012[0.30] D D HEAD DIM. .098 2.50 .100 2.54 .158 4.02 .025 0.64 C C A .100 2.54 RECOMMENDED PCB LAYOUT B A .039 1.00 B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK. 2. CONTACT MATERIAL: SEE PART NUMBER CODING. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 3 AMPS PER CONTACT. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: 1000 VAC. 8. OPERATING TEMPERATURE: SEE PART NUMBER CODING. 9. *PROCESSING TEMP.: SEE PART NUMBER CODING. DRAWN *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 6 5 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: ANGULAR: .XX= .012 [.30] .XXX= .008 [.20] .XXXX= .0040 [.100] RoHS COMPLIANT 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 03/21/2011 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER MALE .100"[2.54mm]PITCH, RA PART NUMBER SIZE C _ R _C_ _ _S_ _N-M71RC CAGE CODE 54453 SCALE: 4:1 2 DWG. NO. 11637 SHEET 1 OF 1 1 REV B FILE NAME: Z:\ECO PENDING\2422, TAIWAN HEADER 100 CC ADD P PLATING\11637, _ R_C_ _ _S_ _N-M71RC PRINT: 8/26/2011 A
PREC015SBDN-M71RC
物料型号:N-M71RC
器件简介:文档中没有提供具体的器件简介
引脚分配:文档提供了不同型号的引脚分配,例如C002S、C003S、C004S等,每个型号都有其特定的头部尺寸、尾部尺寸和引脚间距。
参数特性: - 绝缘体材料:PBT/黄铜,工作温度范围为-40°C至+105°C。 - 接触材料:尼龙6T/黄铜,工作温度范围同样为-40°C至+105°C。 - 接触表面镀层:有金和纯锡的镀层选项。 - 电流额定值:每个接触点3安培。 - 绝缘体电阻:最小5000兆欧。 - 接触电阻:最大20毫欧。 - 耐电压:1000 VAC。
功能详解:文档中没有提供详细的功能解释,但根据参数特性可以推断该器件可能用于电子设备的连接。
应用信息:文档中没有提供具体的应用信息
封装信息:文档提供了推荐的PCB布局和引脚分配信息,但没有提供封装的详细描述。
PREC015SBDN-M71RC 价格&库存
很抱歉,暂时无法提供与“PREC015SBDN-M71RC”相匹配的价格&库存,您可以联系我们找货
