HRG
SUSUMU CO.,LTD
High Power Thin Film Chip Resistor 1206 1W Power
FEATURES
• Excellent reliability and stability even under harsh conditions
• Low noise, THIN FILM construction
• EIA Standard 1206 with 1W Power
• RoHS Compliance and 100% Lead-Free
・AEC-Q200 Qualified
・Anti- Sulfur
・Moisture Resistant
APPLICATIONS
Power supplies
Power switching
Braking system
Test and measurement equipment
Motor deflection circuits
Electrical Specification
Type
Size
(in inch)
Power Rating
Resistance
Tolerance
Resistance Range (ohm)
*E24 & E96 series R value
TCR
Packaging
±25ppm/℃(P)
±0.1%(B)
HRG3216
1206
47 - 100k
±50ppm/℃(Q)
1.0W
±25ppm/℃(P)
47 - 100k
±50ppm/℃(Q)
10 - 100k
±0.5%(D)
Tape & Reel
T1 = 1000pcs
T5 = 5000pcs
Reliability Specification
Test Item
Load Life
Temp. Hum. Bias
Thermal Shock
High Temp. Exposure
Test Method (JIS C5201-1)
ΔR Limits
70℃, rated power, 90min. on/ 30min. Off, 1000hrs.
Under 47Ω
±(0.5%+0.05Ω)
47Ω and higher
±(0.25%+0.01Ω)
85oC 85% RH, 1/10 rated power, 90min. on/ 30min. Off, 1000hrs.
-55oC (30min)/room temp.(2min) /+125oC(30min)/room temp.(2min),
no bias, 1000 cycles
Under 47Ω
±(0.25%+0.05Ω)
47Ω and higher
±(0.1%+0.01Ω)
155oC for 1000h, no bias.
Dimensions
Unit (mm)
Type
HRG3216
Dimensions
W
3.2±0.2
L
1.65±0.2
t
0.45±0.1
a
0.5±0.25
b
1.1±0.2
www.susumu.co.jp
1 ページ
HRG
SUSUMU CO.,LTD
Recommended Land Pattern
d
Unit (mm)
b
a
b
Solder
Resist
Solder
Resist
c
Chip Componment
Solder pad
TYPE
a
b
c
d (*1)
(Reference value)
3216
0.55±0.1
1.9±0.1
1.8±0.1
27.0±0.1
(*1) Please give consideration to heat dissipation of the resistor.
The solder fillet when resistor is powered up should not exceed
155℃.
Power Derating Curve
(HRG3216)
For operation above 70℃, power must be derated according to the following chart.
However, in actual use, verify the fillet temperature is not exceeding 155℃.
Percent of the rated dissipation
100
Area of Recommended Operation
50
70
100
150
Ambient Temperature(℃)
www.susumu.co.jp
2 ページ
HRG
SUSUMU CO.,LTD
ΔR/R (%)
Load Life @ 70℃ at Rated Power 1.0W
0.12%
0.10%
0.08%
0.06%
0.04%
0.02%
0.00%
-0.02%
-0.04%
-0.06%
-0.08%
-0.10%
-0.12%
HRG3216:10kΩ
10h
100h
Time(hours)
1000h
10000h
ΔR/R (%)
Temperature Humidity Bias
0.12%
0.10%
0.08%
0.06%
0.04%
0.02%
0.00%
-0.02%
-0.04%
-0.06%
-0.08%
-0.10%
-0.12%
HRG3216:10kΩ
10h
100h
Time(hours)
1000h
10000h
ΔR/R (%)
Thermal Shock -55℃ - +125℃
0.12%
0.10%
0.08%
0.06%
0.04%
0.02%
0.00%
-0.02%
-0.04%
-0.06%
-0.08%
-0.10%
-0.12%
10cycle
HRG3216:10kΩ
100cycle
Time(hours)
1000cycle
10000cycle
ΔR/R (%)
High Temperature Exposure at 155℃ with no power
0.12%
0.10%
0.08%
0.06%
0.04%
0.02%
0.00%
-0.02%
-0.04%
-0.06%
-0.08%
-0.10%
-0.12%
10h
HRG3216:10kΩ
100h
Time(hours)
1000h
10000h
www.susumu.co.jp
3 ページ
HRG
SUSUMU CO.,LTD
Recommended Reflow Profile
Tape & Reel Dimensions (mm)
unit(mm)
TYPE
A
B
W
F
E
P0
P1
P2
D0
D1
T
t
HRG3216 2.0±0.2 3.6±0.2 8.0±0.3 3.5±0.05 1.75±0.1 4.0±0.1 4.0±0.1 2.0±0.05 1.55±0.05 1.05±0.05 1.5 max 0.3 max
Sprocket hole
t
P0
φD0
P2
W
B
F
E
φD1
Cavity
P1
A
T
Ordering information
HRG
3216
Type
Size
P
TCR
3216
P = ±25ppm/℃
Q = ±50ppm/℃
1001
B
R-Values
T5
Tolerance
4digits for all
values E24 & E96
(Ex.47R0=47 ohm)
(Ex.1000=100 ohm)
(Ex.4992=49.9k ohm)
B = ±0.1%
D = ±0.5%
Package
T&R
T1 = 1000pcs T&R
T5 = 5000pcs T&R
Notice
For non-standard R-value requests, please contact our technical support.
www.susumu.co.jp
4 ページ
很抱歉,暂时无法提供与“HRG3216P-2612-B-T5”相匹配的价格&库存,您可以联系我们找货
