TG832-288-192-2.0
TG832-288-192-2.0
    T-GLOBAL
    TG832 288X192X2MM
TG832-288-192-2.0 数据手册
TG832 Ultra-Soft Thermal Conductive Pad Version 1.131017 Ultra-Soft Thermal Conductive Pad TG832 is an ultra-soft, silicone based thermal interface material. TG832 has a low thermal impedance, conforms readily to surfaces due to its low hardness and provides a high dielectric breakdown voltage. TG832 can be provided in various thicknesses and formats, such as custom die cuts, standard sheets. Features Superior thermal conductivity Highly compressible Naturally tacky Low Shore 00 hardness Low oil bleed Electrically insulating Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property TG832 Colour Unit Tolerance Test Method Pink - - Visual 0.5 - 5.0 mm - ASTM D374 0.0197 - 0.1969 inch - ASTM D374 Thermal Conductivity 5 W/mK ±0.4 ASTM D5470 Flammability Rating V-0 - - UL 94 Dielectric Breakdown Voltage 16 kV/mm ±1.5 ASTM D149 Thickness Weight Loss ‹1 % - ASTM E595 Density 2.3 g/cm³ ±0.2 ASTM D792 Working Temperature -45 to 200 ˚C - - Volume Resistance ›10¹² Ohm-cm - ASTM D257 Elongation 300 % - ASTM D412 Tensile Strength 1 Kgf/cm² - ASTM D412 Hardness 40 Shore 00 ±5 ASTM D2240 Part Number Information TG832 T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 Product Length Width Thickness TG832 288mm 192mm 0.5mm-5.0mm NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and liability incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing future patents covering any product or material or its use.
TG832-288-192-2.0 价格&库存
很抱歉,暂时无法提供与“TG832-288-192-2.0”相匹配的价格&库存,您可以联系我们找货
