DC0011/05-TI900-0.12-0 数据手册
Ti900
Thermally Conductive Insulators
Version 3.01042019
Thermal Conductive Insulators
Ti900 is a high thermal performance insulator pad designed to maximize thermal
conductivity and electrical isolation performance for a wide variety of applications.
The unique formulation offers a smooth and compliant surface which minimizes
interfacial thermal resistance at low mounting forces.
Features
High insulation strength
Low thermal resistance
Die cut for custom shapes
Easy to assemble
Applications
Electronic components: IC, CPU, MOS
LED, M/B, P/S, Heat Sink
LCD, TV, Notebook PC, PC Telecom Device, Wireless, etc.
DDR II Module, DVD Applications, Hand-set applications, etc.
Properties
REACH Compliant
ROHS Compliant
Property
T-Global Technology Limited
1 & 2 Cosford Business Park, Central Park,
Lutterworth, Leicestershire LE17 4QU U.K.
Tel: +44 (0)1455 553 510
Email: sales@tglobaltechnology.com
Web: www.tglobaltechnology.com
Skype: tglobal.technology
VAT #: GB 116 662 714
Ti900
Unit
Test Method
Colour
Grey
Visual
Viscose
One Side
ASTM D374
Thickness
0.12
mm
Base
RITF
Thermal Conductivity
1.8
W/mK
ASTM D5470
Thermal Resistance @ 10psi
0.50
K in²/W
ASTM D5470
Thermal Resistance @ 30psi
0.42
K in²/W
ASTM D5470
Thermal Resistance @ 50psi
0.35
K in²/W
ASTM D5470
Thermal Resistance @ 100psi
0.29
K in²/W
ASTM D5470
Thermal Resistance @ 200psi
0.28
K in²/W
ASTM D5470
Thermal Resistance @ 400psi
0.27
K in²/W
ASTM D5470
Insulation Strength Vac, V
›6000
ASTM D149
Volume Resistance
›10¹²
Ohm-cm
ASTM D257
Working Temperature
-50 to 180
oc
Tensile Strength
5000
psi
ASTM D412
Elongation
40
ASTM D412
Flammability Rating
V-0
UL94
Shelf Life
36
months
Shelf Life with adhesive
(can be requalified for further 12)
12
months
Ti900
Standard Weights & Dimensional Tolerance
Size
Thickness (mm)
0.12
Thickness (mm)
Tolerance (mm)
100x100
0.96
0.3
±0.03
150x150
2.16
0.5
±0.05
300x300
8.64
0.8
±0.08
320x320
9.83
1.0
±0.1
1.2
±0.12
1.5
±0.15
2.0
±0.2
2.5 - 3.5
±0.25
4.0 - 4.5
±0.3
5.0
±0.35
6.0 - 8.0
±0.4
* All measurements in weights are in gr
** All sizes are in mm
Die-Cut
Thickness
Tolerances
9.0
±0.45
10.0
±0.5
>10.0
±0.5
* Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application.
NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our
control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the
suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise,
except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation,
or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are
assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in
conflict with existing or future patents covering any product or material or its use.
Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
DC0011/05-TI900-0.12-0 价格&库存
很抱歉,暂时无法提供与“DC0011/05-TI900-0.12-0”相匹配的价格&库存,您可以联系我们找货
