TI900-50M-320-0.12-0
    T-GLOBAL
    THERM PAD 50MX320MM WHITE
TI900-50M-320-0.12-0 数据手册
Ti900 Thermally Conductive Insulators Version 3.01042019 Thermal Conductive Insulators Ti900 is a high thermal performance insulator pad designed to maximize thermal conductivity and electrical isolation performance for a wide variety of applications. The unique formulation offers a smooth and compliant surface which minimizes interfacial thermal resistance at low mounting forces. Features High insulation strength Low thermal resistance Die cut for custom shapes Easy to assemble Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 Ti900 Unit Test Method Colour Grey - Visual Viscose One Side - ASTM D374 Thickness 0.12 mm - Base RITF - - Thermal Conductivity 1.8 W/mK ASTM D5470 Thermal Resistance @ 10psi 0.50 K in²/W ASTM D5470 Thermal Resistance @ 30psi 0.42 K in²/W ASTM D5470 Thermal Resistance @ 50psi 0.35 K in²/W ASTM D5470 Thermal Resistance @ 100psi 0.29 K in²/W ASTM D5470 Thermal Resistance @ 200psi 0.28 K in²/W ASTM D5470 Thermal Resistance @ 400psi 0.27 K in²/W ASTM D5470 Insulation Strength Vac, V ›6000 - ASTM D149 Volume Resistance ›10¹² Ohm-cm ASTM D257 Working Temperature -50 to 180 oc - Tensile Strength 5000 psi ASTM D412 Elongation 40 % ASTM D412 Flammability Rating V-0 - UL94 Shelf Life 36 months - Shelf Life with adhesive (can be requalified for further 12) 12 months - Ti900 Thermally Conductive Insulators Standard Weights & Dimensional Tolerance Size Thickness (mm) 0.12 Thickness (mm) Tolerance (mm) 100x100 0.96 0.3 ±0.03 150x150 2.16 0.5 ±0.05 300x300 8.64 0.8 ±0.08 320x320 9.83 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 * All measurements in weights are in gr ** All sizes are in mm Die-Cut Thickness Tolerances 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated in T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and all liabilities incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing or future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
TI900-50M-320-0.12-0 价格&库存
很抱歉,暂时无法提供与“TI900-50M-320-0.12-0”相匹配的价格&库存,您可以联系我们找货
