TO5022-680M
TO5022-680M
    TAMURA
    SMD,18.4x15mm
    FIXED IND 68UH 2.3A 130 MOHM SMD
TO5022-680M 数据手册
PRODUCT SPECIFICATION Product Name 5022 SMD POWER INDUCTORS - OPEN TYPE TAMURA Part No. TO5022-XXX Page 1 Rev. No. 0 1.CONFIGURATION & DIMENSIONS : A 101 MARKING INDUCTANCE CODE C B F : : : : : : : : : 15.00±0.3 18.40±0.3 7.00±0.5 2.40±0.2 2.20±0.2 13.30±0.3 12.70 REF. 2.80 REF. 3.00 REF. I G m/m m/m m/m m/m m/m m/m m/m m/m m/m D E H D A B C D E F G H I PCB PATTERN 2. SCHEMATIC DIAGRAM : 3. GENERAL SPECIFICATION : a) TEMP. RISE : 40°C TYP. b) RATED CURRENT : BASE ON TEMP. RISE & LOA=10% TYP. c) STORAGE TEMP. : -40°C ~ +125°C d) OPERATING TEMP. : -25°C ~ +105°C e) RESISTANCE TO SOLDER HEAT : 260°C FOR 10 SECS. TAMURA I PRODUCT SPECIFICATION Product Name 5022 SMD POWER INDUCTORS - OPEN TYPE TAMURA Part No. TO5022-XXX Page 2 Rev. No. 0 4. ELECTRICAL CHARACTERISTICS : RDC ( mOhm ) MAX 9 TO5022-1R0M 1.00±20% 100K SRF ( MHZ ) TYP. 80.0 TO5022-2R2M 2.20±20% 100K 80.0 14 7.10 TO5022-3R3M 3.30±20% 100K 60.0 15 6.20 TO5022-5R6M 5.60±20% 100K 40.0 20 5.30 TO5022-100M 10.00±20% 100K 30.0 31 4.30 TO5022-150M 15.00±20% 100K 22.0 36 4.00 TO5022-220M 22.00±20% 100K 20.0 47 3.50 TO5022-330M 33.00±20% 100K 15.0 66 3.00 TO5022-470M 47.00±20% 100K 9.0 89 2.60 TO5022-680M 68.00±20% 100K 8.0 130 2.30 TO5022-101M 100.00±20% 100K 7.0 190 1.80 TAMURA Part No. INDUCTANCE ( µH ) TEST FREQ. ( HZ ) L TAMURA IDC (A) 8.60 PRODUCT SPECIFICATION oduct Name 5022 SMD POWER INDUCTORS - OPEN TYPE TO5022-XXX AMURA Part No. Page 3 Rev. No. 0 RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERINGS 10 seconds max. Soldering 230°C 200°C Preheating Temperature 100 to 150°C 2 minutes min. 30 seconds max. . PACKAGING INFORMATION : D N B A T G *CARRIER TAPE WIDTH : D P:20 m/m 4 m/m 101 101 101 101 101 101 101 2. DIMENSIONS : (m/m) 3. Q'TY & G.W. PER PACKAGE : TAMURA PRODUCT SPECIFICATION Product Name 5022 SMD POWER INDUCTORS - OPEN TYPE TAMURA Part No. TO5022-XXX Page 4 Rev. No. 0 6. Part No. FORMAT : T O 5 0 2 2 TOLERANCE CODE INDUCTANCE CODE SIZE TYPE CODE TAMURA PREFIX TAMURA PRODUCT SPECIFICATION Product Name 5022 SMD POWER INDUCTORS - OPEN TYPE TAMURA Part No. TO5022-XXX Page 5 Rev. No. 0 7. RELIABILITY TEST : TEST ITEM SPECIFICATION TEST CONDITION SOLDERABILITY MORE THAN 90% OF THE TERMINAL ELECTRODE SHALL BE COVERED WITH FRESH SOLDER. PREHEAT : 125±25°C FOR 60 SECONDS SOLDER : H63A ( EUTECTIC SOLDER ) SOLDER TEMP. : 230±5°C FLUX : ROSIN DIP TIME : 4±1 SECONDS INDUCTANCE SHALL NOT CHANGE MORE THAN ±20% ROOM TEMP. 15 MINUTES -25±2°C 30 MINUTES ROOM TEMP. 15 MINUTES 85±2°C 30 MINUTES THERMAL SHOCK TEST ( TEMP. CYCLE ) TOTAL : 50 CYCLES HUMIDITY RESISTANCE TEST TEMPERATURE : 40±2°C HUMIDITY : 90 ~ 95% APPLIED CURRENT : PER SPEC. TIME : 500 HOURS HIGH TEMP. RESISTANCE TEST TEMPERATURE : 85±2°C APPLIED CURRENT : PER SPEC. TIME : 500 HOURS TAMURA
TO5022-680M 价格&库存
很抱歉,暂时无法提供与“TO5022-680M”相匹配的价格&库存,您可以联系我们找货
