TS3316-4R7M
TS3316-4R7M
    TAMURA
    SMD,12.7x10mm
    FIXED IND 4.7UH 2.7A 40 MOHM SMD
TS3316-4R7M 数据手册
PRODUCT SPECIFICATION Product Name 3316 SMD POWER INDUCTORS - SHIELDED TYPE TAMURA Part No. TS3316-XXX Page 1 Rev. No. 0 1. CONFIGURATION & DIMENSIONS : A 101 MARKING INDUCTANCE CODE C B F : 10.0±0.2 : 12.7±0.2 : 4.9±0.3 : 2.4±0.2 : 2.2±0.2 : 7.6±0.3 : 7.3 REF. : 2.8 REF. : 3.0 REF. m/m m/m m/m m/m m/m m/m m/m m/m m/m D E H D A B C D E F G H I I G I PCB PATTERN 2. SCHEMATIC DIAGRAM : 3. GENERAL SPECIFICATION : a) TEMP. RISE : 40°C MAX. b) RATED CURRENT : BASE ON TEMP. RISE & L / LOA=10% MAX. c) STORAGE TEMP. :-40°C ----+105°C d) OPERATING TEMP. : -25°C----+85°C e) RESISTANCE TO SOLDER HEAT : 260°C FOR 10 SECS. TAMURA PRODUCT SPECIFICATION Product Name 3316 SMD POWER INDUCTORS - SHIELDED TYPE TAMURA Part No. TS3316-XXX Page 2 Rev. No. 0 4. ELECTRICAL CHARACTERISTICS : TS3316-1R0M 1.0±20% 50 100K SRF ( MHZ ) TYP. 130.0 TS3316-1R5M 1.5±20% 60 100K 110.0 22 4.50 TS3316-2R2M 2.2±20% 70 100K 90.0 27 3.80 TS3316-3R3M 3.3±20% 70 100K 70.0 39 3.30 TS3316-4R7M 4.7±20% 70 100K 50.0 40 2.70 TS3316-6R8M 6.8±20% 70 100K 30.0 55 2.20 TS3316-100M 10.0±20% 60 100K 28.0 65 1.50 TS3316-150M 15.0±20% 60 100K 20.0 85 1.50 TS3316-220M 22.0±20% 50 100K 19.0 207 1.30 TS3316-330M 33.0±20% 70 100K 334 1.10 TS3316-470M 47.0±20% 70 100K 15.0 13.0 472 0.80 TAMURA Part No. INDUCTANCE Q ( µH ) REF. TEST FREQ. ( HZ ) L Q TAMURA RDC ( mOhm) MAX 21 IDC (A) 5.00 PRODUCT SPECIFICATION 3316 SMD POWER INDUCTORS - SHIELDED TYPE Product Name TAMURA Part No. TS3316-XXX Page 3 Rev. No. 0 RECOMMENDED SOLDERING CONDITIONS REFLOW SOLDERINGS 10 seconds max. Soldering 230°C 200°C Preheating Temperature 100 to 150°C 2 minutes min. 30 seconds max. 5. PACKAGING INFORMATION : D A B N T G *CARRIER TAPE WIDTH : D P:16 m/m 4 m/m 101 101 101 101 101 101 101 101 ( 2 ) DIMENSIONS Unit:m/m STYLE A B C D G N T 13 - 24 330 21±0.8 13 24 26 MAX 50 MIN 30.4 ( 3 ) Q'TY & G.W. PER PACKAGE OUTER : CARTON INNER : REEL SERIES TS3316 Q'TY (PCS) G.W. (gw) STYLE Q'TY (PCS) G.W. (Kg) SIZE (cm) 500 1000 13 - 24 1000 2 40 x 40 x 24 TAMURA PRODUCT SPECIFICATION Product Name 3316 SMD POWER INDUCTORS - SHIELDED TYPE TAMURA Part No. TS3316-XXX Page 4 Rev. No. 0 6. Part No. FORMAT : T S 3 3 1 6 TOLERANCE CODE INDUCTANCE CODE SIZE TYPE CODE TAMURA PREFIX TAMURA PRODUCT SPECIFICATION Product Name 3316 SMD POWER INDUCTORS - SHIELDED TYPE TAMURA Part No. TS3316-XXX Page 5 Rev. No. 0 7. RELIABILITY TEST : TEST ITEM SPECIFICATION TEST CONDITION SOLDERABILITY MORE THAN 90% OF THE TERMINAL ELECTRODE SHALL BE COVERED WITH FRESH SOLDER. PREHEAT : 125±25°C FOR 60 SECONDS SOLDER : H63A ( EUTECTIC SOLDER ) SOLDER TEMP. : 230±5°C FLUX : ROSIN DIP TIME : 4±1 SECONDS INDUCTANCE SHALL NOT CHANGE MORE THAN ±20% ROOM TEMP. 15 MINUTES -25±2°C 30 MINUTES ROOM TEMP. 15 MINUTES 85±2°C 30 MINUTES THERMAL SHOCK TEST ( TEMP. CYCLE ) TOTAL : 50 CYCLES HUMIDITY RESISTANCE TEST TEMPERATURE : 40±2°C HUMIDITY : 90 ~ 95% APPLIED CURRENT : PER SPEC. TIME : 500 HOURS HIGH TEMP. RESISTANCE TEST TEMPERATURE : 85±2°C APPLIED CURRENT : PER SPEC. TIME : 500 HOURS TAMURA
TS3316-4R7M 价格&库存
很抱歉,暂时无法提供与“TS3316-4R7M”相匹配的价格&库存,您可以联系我们找货
