DTL304
DTL304
    KLEINTOOLS
    UPS 525VA 300W 120V 6OUT W/RJ11
DTL304 数据手册
Tripp Lite 1111 West 35th Street Chicago, IL 60609 USA Telephone: +(773) 869 1234 E-mail: saleshelp@tripplite.com Model #: INTERNET350U Internet Office 350VA Ultra-compact Standby 120V UPS with USB port Highlights 350VA ultra-compact UPS Maintains 120V nominal output during blackouts Workstation optimized features include HID-compliant USB port, single line TEL / DSL line surge suppression and three surge only outlets 99% line-mode efficiency saves energy and operating costs Input: NEMA 5-15P (120V 15A) / Output: 6 NEMA 5-15R (120V) 3 year product warranty / $100,000 Ultimate Lifetime Insurance (USA, Puerto Rico & Canada only) Description Tripp Lite's INTERNET350U standby UPS system offers complete protection from blackouts, brownouts and transient surges on both AC and dialup modem lines. Provides seamless battery support during brownouts and power failures with enough runtime to save and shutdown connected equipment without data loss. Offers complete power protection in an ultra-compact, flat-pack housing with an appearance closer to a power strip than other bulky UPS designs. Includes 3 battery supported outlets for computer, monitor and one vital system peripheral, plus 3 additional surge suppression-only outlets for printers and other system accessories not requiring battery support. USB port enables optional unattended system shutdown without data loss in the case of extended power failure. PowerAlert software available via free download from www.tripplite.com, includes bundled USB cable. Built-in single line RJ11 phone suppression jacks with line splitter protects up to two directly connected modems, fax machines, cordless phones or other peripherals with a standard dialup phone connection. Built-in audible alarm and front panel LEDs offer continuous status information regarding line and battery power operation. 350VA/180 watt power handling ability supports entry-level PC systems for up to 15 minutes during power fail conditions. 3 year warranty. $100,000connected equipment insurance (USA, Puerto Rico, & Canada Only). Package Includes INTERNET350U UPS System USB communications cable Instruction manual with warranty information Features INTERNET350U standby UPS offers complete protection from blackouts, brownouts and surges on both AC and TEL/DSL line connections 6 widely spaced outlets accommodate large transformer plugs without blocking outlets 3 battery supported outlets protect computer, monitor and vital system peripherals, plus 3 additional surge suppression-only outlets for printers and other system accessories not requiring battery support Provides battery derived AC output during blackouts and brownouts 350VA/180 watt power handling ability supports a variety of PCs, workstations and other sensitive electronics Supports entry-level PC systems up to 12 minutes during blackout conditions Built-in single line TEL/DSL line surge suppression protects modems, fax machines or cordless phones on a single phone line connection USB port, free PowerAlert software (available via web download) and cabling offer safe unattended shutdown without data loss during extended outages HID-compliant USB interface enables integration with built-in power management and auto-shutdown features of Windows and Mac OS X. Supports Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application/OS or hard Supports Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application/OS or hard power off/on reboot of connected equipment - ideal for unattended kiosk applications Space saving, ultra-compact housing fits almost anywhere Specifications OUTPUT Output Volt Amp Capacity (VA) 350 Output Watt Capacity (watts) 180 Nominal Output Voltage(s) Supported 115V; 120V Frequency compatibility 60 Hz Output voltage regulation (Battery mode) 115V (+/- 5%) Built-in UPS output receptacles 6 5-15R outlet(s) Surge suppression only outlets 3 UPS outlets, 3 surge-only outlets Output AC waveform (AC mode) Sine wave Output AC waveform (battery mode) PWM sine wave INPUT Rated input current (at maximum load) 10A Nominal Input Voltage(s) Supported 120V AC UPS input connection type 5-15P UPS Input cord length (ft.) 6 UPS Input cord length (m) 1.8 Recommended Electrical Service 15A 120V BATTERY Full load runtime (minutes) 3 minutes (180w) Half load runtime (minutes) 11 minutes (90w) DC system voltage (VDC) 12 LEDS ALARMS & SWITCHES LED Indicators 2 LEDs indicate power status and overload/check battery status Alarms Audible alarm indicates power-failure and overload status Switches Combination switch controls on/off power status and self-test operation SURGE / NOISE SUPPRESSION UPS AC suppression joule rating 380 joules EMI / RFI AC noise suppression Yes PHYSICAL Installation form factors supported with included accessories Tower; Ultra-compact desktop; Wallmount (using keyhole mounting tabs) Primary form factor Desktop UPS / Power Module dimensions in primary form factor (height x width x depth / inches) 3 x 8 x 6.4 UPS / Power Module dimensions in primary form factor (height x width x depth / cm) 7.5 x 20.4 x 16.1 UPS / Power Module weight (lbs) 5 UPS / Power Module weight (kg) 2.3 UPS Shipping dimensions (height x width x depth / inches) 4.1 x 11.3 x 7.7 UPS Shipping dimensions (height x width x depth / cm) 10.5 x 28.7 x 19.5 Shipping weight (lbs) 5.8 Shipping weight (kg) 2.6 UPS housing material ABS ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC mode BTU / hr. (full load) 6 Battery mode BTU / hr. (full load) 134.3 COMMUNICATIONS Communications interface USB (HID enabled) PowerAlert software Free download from www.tripplite.com Communications cable USB interface cable included WatchDog compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications LINE / BATTERY TRANSFER Transfer time 4 milliseconds (AC to battery mode) / 2 milliseconds (Battery to AC mode) Low voltage transfer to battery power (setpoint) 99 High voltage transfer to battery power (setpoint) 139 SPECIAL FEATURES Cold Start (startup in battery mode during a power failure) Cold-start operation supported Green & high efficiency features Greater than 95% efficiency - GREEN UPS CERTIFICATIONS UPS Certifications Tested to UL1778 (USA); Tested to CSA (Canada); Tested to NOM (Mexico); Meets FCC Part 15 Category B (EMI) WARRANTY Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 connected equipment insurance Related Items Optional Products Product Type Related Model Description Qty. USB Cables & Adapters U005-10I 10-inch USB A/A Gold Extension Cable (USB-A Right Angle Male to USB-A Female) - Software WATCHDOGSW WatchDog Service Monitoring / Reboot Software - Audio Cables CT120 Instant-Read- AC Outlet Circuit Tester - Surge Protectors DNET1 Network Surge Suppressor - Essential protection for data and communication lines - USB Hubs/Accessories U222-004-R 4-Port USB2.0 Ultra-Mini Hub - Surge Protectors DTEL2 Network Surge Suppressor - Essential protection for data and communication lines - Extended Warranties WEXT5-INTERNET 5-Year Extended Warranty - For Internet Office, AVR and ECO Series UPS Systems - More information, including related products, owner's manuals, and additional technical specifications, can be found online at www.tripplite.com/en/products/model.cfm?txtModelID=2663. Copyright © 2010 Tripp Lite. All rights reserved. All trademarks are the sole property of their respective owners. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Photos may differ slightly from final products.
DTL304
物料型号:INTERNET350U
器件简介:Tripp Lite的INTERNET350U是一款超紧凑型备用不间断电源(UPS)系统,提供对停电、电压下降和电压瞬变在交流电和拨号调制解调器线路上的全面保护。它在电压下降和电源故障期间提供无缝的电池支持,并有足够的运行时间来保存数据并安全关闭连接的设备。
引脚分配:文档中提到3个电池支持的插座用于电脑、显示器和关键系统外围设备,另外还有3个仅提供浪涌保护的插座用于打印机和其他不需要电池支持的系统附件。
参数特性: - 输出容量:350VA / 180瓦特 - 支持的电压:115V、120V - 输出频率:60Hz - 电池模式下的输出电压调节:115V(+/-5%) - UPS输出插座:6个NEMA 5-15R插座 - 浪涌保护插座:3个UPS插座,3个仅浪涌保护插座 - AC模式下的输出波形:正弦波 - 电池模式下的输出波形:PWM正弦波
功能详解: - 提供电池派生的交流输出,在停电和电压下降期间 - 支持多种PC、工作站和其他敏感电子设备 - 在停电条件下支持入门级PC系统长达12分钟 - 内置单线TEL/DSL线路浪涌保护,保护调制解调器、传真机或无绳电话 - USB端口、免费的PowerAlert软件和电缆,在长时间停电期间提供安全的无人值守关机,以防止数据丢失
应用信息:适用于入门级PC系统,在电源故障条件下可支持最多15分钟。
封装信息: - 主要形态因素:桌面型 - UPS/电源模块尺寸:3x8x6.4英寸(7.5x20.4x16.1厘米) - UPS/电源模块重量:5磅(2.3千克) - 工作温度范围:+32到+104华氏度/0到+40摄氏度 - 存储温度范围:+5到+122华氏度/-15到+50摄氏度 - 相对湿度:0到95%,不凝结
DTL304 价格&库存
很抱歉,暂时无法提供与“DTL304”相匹配的价格&库存,您可以联系我们找货
