O M N I S M A R T™
LINE INTERACTIVE UPS SYSTEMS
1111 W. 35th Street, Chicago IL 60609
www.tripplite.com
“Tripp Lite’s prices are lower,
and the quality is a lot higher ...
All of our Tripp Lite products
have performed flawlessly.”
Movie Gallery
Ben Harris
System Administrator
PROTECTS PCs,
WORKSTATIONS AND
SERVERS
· Automatically Regulates
Incoming Voltage
Automatic Voltage Regulation
keeps computers working through
low voltage (brownouts) and
high voltage conditions.
· Provides Reliable Battery
Power During Blackouts
Allows you to work safely
through short blackouts and
safely shut down your system
during longer ones.
· Automatically Saves Files
During Blackouts
Built-in serial port and FREE
PowerAlert Software to automatically save files and shut
down equipment during a blackout.
· Protects Against Lightning
and Surges . . . Guaranteed
Stops damaging surges and
filters disruptive line noise.
Ultimate Lifetime Insurance
guarantees protection for life!
Complete Power Protection
Automatic Voltage
Regulation (AVR)
OmniSmart gives you everything you need
to protect your computer system in a single
OmniSmart UPS Systems’ AVR feature keeps
box. OmniSmart provides complete protec-
your
computer
low
tion against all types of power problems
voltage
(brownouts, blackouts, surges and line
conditions indefinitely, without using bat-
noise). AVR supports your equipment dur-
tery power. Abnormally low and high voltage
ing brownouts. Up to 1400 VA of battery
conditions are created within your building
backup gives you time to save your open
by increased local demand on your power
files and safely shut down your computer in
circuits (from copiers, air conditioners and
the event of a blackout. In addition, all AC
industrial equipment) or by inadequate
outlets stop damaging lightning and surges.
utility company service. OmniSmart’s built-
Select OmniSmart models also protect your
in micro-processor constantly monitors in-
modem and other communications hard-
coming voltage levels. When it detects high
ware against surges on up to two phone
or low voltage, OmniSmart adjusts it to
lines. $50,000 Ultimate Lifetime Insurance
ensure your connected equipment receives
coverage guarantees your critical equipment
only
will stay safe from surge damage for life!
voltage
working
(brownouts)
regulated,
OmniSmart
tery charge, even
regulating
so
they
are always ready
to
support
computer
high
power.
UPS
maintain their bat-
voltage,
through
computer-grade
Systems constantly
while
and
your
when
blackouts occur.
OmniSmart
takes a
wide range
of incoming
voltage ...
... And
adjusts
it to
Nominal
120V AC
Automatic Data Protection
OmniSmart UPS Systems save your data during
NEW FEATURE FOCUS
a blackout, even when you aren’t there! Each
OmniSmart UPS’s new features provide more power protection and more
model features a built-in serial port which
user convenience:
connects the OmniSmart to any PC, workstation
or server. Use with FREE PowerAlert Software
and cabling to automatically save your open files
Modem/Fax Surge
Protection
Convenient Battery
Replacement Door
Optimal Outlet
Array
Protects your online
Tripp Lite UPS batteries
equipment against
will constantly protect
lightning and surge
your equipment for up
damage on
to 6 years with normal
modem/fax lines.
use. The convenient
700 VA model stops
access door saves the
500 and 700 VA models
surges on two lines
hassle of returning
feature 6 surge-protected
simultaneously,
the UPS for battery
outlets (3 of which also
offering convenient
replacement and service.
provide battery backup for
and shut down equipment during a blackout.
When the power fails, PowerAlert waits for a
user-specified length of time, then saves your
active data files first, before closing application
and operating system software. This preserves
all of your work, regardless of the last time your
files were saved. After PowerAlert shuts down
your equipment, the UPS automatically shuts
down to conserve battery power.
Advanced Power
Condition Warnings
OmniSmart’s microprocessor-controlled warning
lights alert you to potential power problems
before they affect your equipment.
Automatic Voltage Regulation: UPS is
correcting low or high voltage to provide your
equipment with safe 120V AC power.
protection for multi-
your critical equipment).
line homes and
Connect and protect all your
businesses.
equipment (computer, monitor,
300 and 500 VA
printer and peripherals) with
models stop surges
one UPS. Wide outlet spacing
on a single line.
keeps all outlets accessible,
even with transformers.
AC Line Voltage: UPS is providing your
equipment with surge-protected AC
linepower.
“The power in our building is often suspect. We
Using Battery: UPS is providing your
invested in one of your UPS systems. During a severe
equipment with battery power during a
blackout or brownout.
brownout, the UPS kicked in and provided protection
for our system. Our data stayed secure. Tripp Lite is at
Battery Low/Replace: Indicates low
the top of our list for quality UPS equipment.”
battery charge.
Laser Renewal, Inc.
UPS Load: UPS’s capacity has
been exceeded.*
Matt Spencer
*On 850 VA models and higher.
Model
Capacity
(VA/Watts)
Backup Time
Half Load/
Full Load
(typical minutes)
AC Receptacles
(NEMA 5-15R)
Serial Port
Modem/Fax
Protection
(type)
Dimensions
HxWxD
(inches)
Shipping
Weight
(lbs)
OmniSmart (includes PowerAlert Software)
OMNISMART 300
300/180
17/5
3
1
1 line (RJ11)
8¼ x 4¾ x 7
13
OMNISMART 500
500/300
17/5
6 (3 UPS/3 Surge)
1
1 line (RJ11)
8¼ x 4¾ x 7
15½
OMNISMART 700
700/425
17/5
6 (3 UPS/3 Surge)
1
2 line (RJ11)
10½ x 4¾ x 7
20½
OMNISMART 850
850/570
26/9
6
1
12¾ x 6½ x 8¾
28
OMNISMART 1050
1050/705
23/7
6
1
12¾ x 6½ x 8¾
37
OMNISMART 1400
1400/940
24/8
6
1
10 x 6½ x 14
44
OmniPro*
OMNIPRO 300*
300/175
17/5
3
8¼ x 4½ x 5¾
13
OMNIPRO 500*
500/300
17/5
6 (3 UPS/3 Surge)
1
1 line (RJ11)
8¼ x 4¾ x 7
15½
*Does not include PowerAlert Software/cabling.
FOR MORE INFORMATION ON TRIPP LITE PRODUCTS, VISIT OUR WEBSITE: www.tripplite.com
1111 W. 35TH STREET, CHICAGO, IL 60609 • Phone: (773) 869-1234
200004158 5/00 95-1830
很抱歉,暂时无法提供与“OMNI SMT300PNP”相匹配的价格&库存,您可以联系我们找货
