SL2493SU
SL2493SU
    WINTECINDUSTRIES
    Module
SL2493SU 数据手册
Wintec Industries – OEM Embedded Design Center Where to Buy | Contact Us CONSUMER EMBEDDED OEM SUPPLY CHAIN   CLOUD SERVICES DISTRIBUTION Submit SUPPORT ABOUT WINTEC     Embedded OEM   Home >   Embedded OEM  >  Embedded Modems  >  SL Embedded Modems   DRAM Embedded Modems Flash SL-SU Series SSD SL-SU Series SLM Series USB Modem ADD2   Modems Wintec’s embedded modem is based on a Silicon Labs ISO modem chipset. There is a long product history with this embedded modem at Wintec. Two different interfaces have been implemented for this product to meet various customer demands. One is a parallel mode interface where the data transactions between the host and the modem use an 8-bit data bus with a set of micro-controller control signals at the interface. The other uses an UART interface, where the embedded modem is operates in serial mode to handle data transfer with the host system. SLM SL-SU USB Modem Wintec is committed to long term support of embedded modems products. This includes maintaining long term product revisions, which allows communication and medical system customers the longevity of a product to pass FCC and FDA certifications. Wintec maintains two families of embedded modem products that span two generations of Silicon Labs modem chipsets. Wintec also provides a 1.4” x 0.9” 24 pin small form factor solution. The smaller and more compact SL24xx Series modems support serial mode only. See SL Modem tab for more info.         SL-SU Series Standard Part Number Error Correction Data Compression RoHS FCC Support Support Compliant 6/6 Certified Maximum Speed SL2404SU 2.4Kbps (V.22bis) V.42 V.42bis Yes Yes SL2415SU 14.4Kbps (V.32bis) V.42 / MNP2-4 V.42bis / MNP5 Yes Yes SL2434SU 33.6Kbps (V.34) V.42 / MNP2-4 V.42bis / MNP5 Yes Yes SL2457SU 56Kbps/33.6Kbps (V.90) V.42 / MNP2-4 V.42bis / MNP5 Yes Yes SL2493SU 56Kbps/48Kbps (V.92) V.42 / MNP2-4 V.42bis / MNP5 Yes Yes http://www.wintecind.com/oem/Modems/SL_Modem.html[4/19/2012 3:57:20 PM]
SL2493SU 价格&库存
很抱歉,暂时无法提供与“SL2493SU”相匹配的价格&库存,您可以联系我们找货
