Wintec Industries – OEM Embedded Design Center
Where to Buy | Contact Us
CONSUMER
EMBEDDED OEM
SUPPLY CHAIN
CLOUD SERVICES
DISTRIBUTION
Submit
SUPPORT
ABOUT WINTEC
Embedded OEM
Home > Embedded OEM > Embedded Modems > SLM Embedded Modems
DRAM
Embedded Modems
Flash
SLM Series
SSD
SL-SU Series
SLM Series
USB Modem
ADD2
Modems
Wintec’s embedded modem is based on a Silicon Labs
ISO modem chipset. There is a long product history
with this embedded modem at Wintec. Two different
interfaces have been implemented for this product to
meet various customer demands. One is a parallel
mode interface where the data transactions between
the host and the modem use an 8-bit data bus with a
set of micro-controller control signals at the interface.
The other uses an UART interface, where the
embedded modem is operates in serial mode to handle
data transfer with the host system.
SLM
SL-SU
USB Modem
Wintec is committed to long term support of embedded
modems products. This includes maintaining long term
product revisions, which allows communication and
medical system customers the longevity of a product to
pass FCC and FDA certifications. Wintec maintains two
families of embedded modem products that span two
generations of Silicon Labs modem chipsets.
Both generations of SLM embedded modems are in 2” x
1” DIP form factor and are often referred to as a DIP
modems. There are 40 total number of pins in the DIP
modem and each pin has a pin pitch of 0.1 inches.
Wintec also provides a 1.4” x 0.9” 24 pin small form
factor solution. The smaller and more compact SL24xx
Series modems support serial mode only. See SL
Modem tab for more info.
SLM Series
Standard and I-Temp
Part Number
Error Correction
Data Compression
RoHS
FCC
Support
Support
Compliant 6/6
Certified
Maximum Speed
SLM2404(-I)
2.4Kbps (V.22bis)
V.42
V.42bis
Yes
Yes
SLM2415(-I)
14.4Kbps (V.32bis)
V.42 / MNP2-4
V.42bis / MNP5
Yes
Yes
SLM2434(-I)
33.6Kbps (V.34)
V.42 / MNP2-4
V.42bis / MNP5
Yes
Yes
SLM2457(-I)
56Kbps/33.6Kbps (V.90)
V.42 / MNP2-4
V.42bis / MNP5
Yes
Yes
SLM2493(-I)
56Kbps/48Kbps (V.92)
V.42 / MNP2-4
(-I) = I-Temp -40˚ to +85˚C optional
xxx = BNA: Bulk, no accessories
BWA: Bulk, with accessories (RJ11 cable, CD installation)
RWA: Retail with accessories (RJ11 cable, CD installation)
All Modems are FCC and CTR/TBR-21 Certified.
CONTACT US
SITEMAP
JOBS |
PRESS
PRIVACY
WEBSITE FEEDBACK
COPYRIGHT © 2011 WINTEC INDUSTRIES ALL RIGHTS RESERVED
http://www.wintecind.com/oem/Modems/SLM_Modem.html[4/19/2012 4:04:21 PM]
V.42bis / MNP5
Yes
Yes
很抱歉,暂时无法提供与“SLM2493”相匹配的价格&库存,您可以联系我们找货
