W2DM032G1TC-J51MA2-2D2.01
    WINTECINDUSTRIES
    SSD 32GB SATA DOM MLC SATA II 5V
W2DM032G1TC-J51MA2-2D2.01 数据手册
Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series INFORMATION IN THIS DOCUMENT IS PROVIDED IN RELATION TO WINTEC INDUSTRIES PRODUCTS, AND IS SUBJECT TO CHANGE WITHOUT NOTICE. NOTHING IN THIS DOCUMENT SHALL BE CONSTRUED AS GRANTING ANY LICENSE, EXPRESS OR IMPLIED. ALL INFORMATION IN THIS DOCUMENT IS PROVIDED ON AN “AS-IS” BASIS WITHOUT GUARANTEE OR WARRANTY OF ANY KIND. • Please contact your nearest Wintec representative for the latest updates or additional product information. WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 1 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series Revision History Revision Month Year 1.0 Jan 2012 History Preliminary Release WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 2 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series Table of Contents 1.0 2.0 3.0 4.0 5.0 General Product Specification ......................................................................................................................... 5 Electrical Specification.................................................................................................................................... 7 Software Interface ........................................................................................................................................... 8 Physical Specifications .................................................................................................................................. 11 Ordering Information .................................................................................................................................... 12 WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 3 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series Wintec SATA DOM WxDMxxxG1TC-J51xx Series Features: GENERAL • Density up to 128GB • JMicron 605 controller • SATA-II interface and backwards compatible • High-Performance SLC or MLC NAND Flash memory PERFORMANCE • Read Performance 60MB/s Seq. Read (SATA-II)* • Write Performance 15MB/s Seq. Write (SATA-II)* • Random Read: 5K IOPS at 4KB transfer (SATA-II)* RELIABILITY • Bad Block Management & Wear Leveling • ECC Engine: Up to 24 bits correctable per 1KB sector • Data Integrity under power-cycling • MTTF: 1,000,000 operating hours Wintec SATA DOM NOTE: See Section 5.0 for Configuration & Ordering Guide COMPATIBILITY • Serial ATA Revision 2.6 Compliant • ATA/ATAPI-7 Compliant • Supports TRIM and S.M.A.R.T commands • RoHS compliant Description: The Wintec Industries WxDMxxxG1TC-J51xx series of ROHS Compliant SATA Disk-On-Module drives are constructed with NAND-type flash memory devices paired to JMicron 605 SSD controller for virtual-to-physical address mapping and other sophisticated flash management functions. The Wintec Flash Solid State Disk (SSD) provides major advantages over the traditional magnetic hard disk drive (HDD). Faster access time and transfer rate, silent operation and low power consumption, better shock and vibration resistance, and lower total cost of ownership make the Wintec SSDs an attractive choice as the next generation mass storage device. The Wintec J5 series SATA DOM provides high-speed data transfer and reliability utilizing SLC or MLC NAND-flash in storage capacities ranging from 1GB to 128GB in compact form factor. Its robust design enables the SSD to achieve outstanding reliability and performance. The JMF605 controller implements bad block management and dynamic/static wear-leveling techniques to ensure that the NAND flash memory is not worn out prematurely. The controller utilizes 24 bits/1K byte sector BCH ECC algorithms for error correction. The drive supports basic SMART features to monitor the drive status and TRIM command to efficiently maintain the data. The Wintec J5 series SATA DOM drives are ideal for portable and desktop computers, point of sale (POS), handheld device, gaming machine, network equipment, notebook, thin-client and set-top boxes (STB). *8GB MLC based performance on IOMeter 2007 with 128KB sequential and 4KB random transfers. *Read/Write performance vary based on Flash type/capacity/configuration and block size used for testing. WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 4 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series 1.0 General Product Specification For all the following specifications, values are defined at ambient temperature unless otherwise stated. Table 1: User Capacity Specifications Model Number¹ (typ)2,3 W7DM001G1TC-J51yyy-zzz.aa W7DM002G1TC-J51yyy-zzz.aa W7DM004G1TC-J51yyy-zzz.aa W7DM016G1TC-J51yyy-zzz.aa W2DM008G1TC-J51yyy-zzz.aa W2DM016G1TC-J51yyy-zzz.aa W2DM032G1TC-J51yyy-zzz.aa W2DM064G1TC-J51yyy-zzz.aa W2DM128G1TC-J51yyy-zzz.aa NAND Flash Type SLC SLC SLC SLC MLC MLC MLC MLC MLC NAND Flash Total Capacity 1GB 2GB 4GB 16GB 8GB 16GB 32 GB 64 GB 128 GB Over-provison 7% 7% 7% 7% 7% 7% 7% 7% 7% NOTE: 1. See Section 5.0 for Configuration & Ordering Guide 2. 1GB = 1,000,000,000 Bytes 3. Capacity available to end-user is less than “Total Capacity” due to flash controller overhead, and may vary with flash configuration. Table 2: Typical Performance Specifications Parameter Sustained Sequential Read Sustained Sequential Write Sustained IOPS Random Read Typical Performance4 up to 60MB/sec (MLC); 80MB/sec (SLC) up to 20MB/sec (MLC); 50MB/sec (SLC) up to 5000 IOPS (MLC); up to 6000 IOPS (SLC) NOTE: 4. Bandwidth measured on high-performance desktop system. Note that performance may also vary depending on host system, drive capacity, and drive configuration. Measured at QD=32. Table 3: Flash Endurance Parameter Spec up to 60,000 cycles for SLC up to 5,000 cycles for MLC 5 Years (Min.) 2,000,000 Hours Program/Erase Cycles Data Retention MTTF Table 4: SSD Data Reliability Parameter Non-Recoverable Errors Raw ECC Correctability Spec < 1 in 1016 Bytes Read Up to 24 bits / 1024 Bytes data Table 5: Environmental Specifications Parameters Temperature Commercial Temp. Humidity (Non-Condensing) Vibration Shock (Operating) Noise WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Operating 0°C to 70°C 5% to 85% 20 G RMS 1,500 G (Max.) 0 dB Revision 1.00 Non-Operating -55°C to 95°C 5% to 95% N/A 0 dB 5 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series 1.1 Block Diagram Flash Controller 1 & ECC Engine SATA Controller Channel 1 SLC/MLC NAND FLASH Channel 2 SLC/MLC NAND FLASH Channel 3 SLC/MLC NAND FLASH Channel 4 SLC/MLC NAND FLASH SATA II I/F 7Pin connector SATA II PHY 5V 2-Pin Jack Voltage Regulator BUS CPU Flash Controller 4 & ECC Engine Figure 1. Block Diagram 1.2 Architecture The Wintec J5 series SSD utilizes a single flash controller chip with 4 parallel channels of flash memory interface. The flash controller also simultaneously manages the file read and write interface with the host system via a single SATA-II interface.By utilizing 4 parallel channels of SLC or MLC flash memory, SATA DOM SSD can provide both high performance and reliability, while maintaining a minimal unit cost. 1.3 Wear leveling The SSD controller tracks the number of PE (program/erase) cycles that each block in the SSD goes through, and will dynamically remap logical sectors written from the host to different physical pages and blocks within the NAND flash. This including with static wear leveling ensures the flash cells wear evenly, and no premature wear out or data loss will occur in any portions of the drive. 1.4 ECC Correction The drive supports BCH error correction code, the controller can correct 16 bits or 24 bits per 1024 byte data. WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 6 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series 2.0 Electrical Specification 2.1 General Table 6: Absolute Maximum Ratings Symbol VCC Parameter VCC With Respect to GND Min -0.5 Max Units 6.0 V Min 4.5 0 -40 5 Max 5.5 70 85 85 Units V °C °C % Idle Power consumption Typical operating power consumption Maximum operating power consumption Value TBD TBD TBD Units Watts Watts Watts Table 7: Typical Operating Conditions (VCC=5V ± 10%) Symbol VCC TA H Parameter VCC With Respect to GND Operating Temperature (Commercial Temp) Operating Temperature (Industrial Temp) Humidity Table 8: Power consumption Symbol Pi PT Pmax 2.2 Parameter SATA Pin Assignment and Description The 7-Pin female SATA connector is used for data bus interface and 2-pin 5V power jack is used to provide operating voltage to the drive through the voltage regulator. Table 9: SATA connector specification compliant No. Signal Plug Connector pin definition S1 GND S2 A+ S3 A- S4 GND S5 B- S6 B+ S7 GND Ground Differential signal A Ground Differential signal B Ground * Design option available to not use the power jack. WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 7 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series 3.0 Software Interface 3.1 ATA Command Set All mandatory, and many optional commands and features are supported. The following tables summarize the ATA feature set and commands. Table 10: ATA Command Command Name CHECK POWER MODE DEVICE CONFIGURATION OVERLAY EXECUTE DIAGNOSTICS FLUSH CACHE FLUSH CACHE EXT IDENTIFY DEVICE IDLE IDLE IMMEDIATE NOP INITIALIZE DEVICE PARAMETERS READ BUFFER READ DMA READ DMA EXT READ FPDMA QUEUED READ LOG EXT READ MULTIPLE READ MULTIPLE EXT READ NATIVE MAX ADDRESS READ NATIVE MAX ADDRESS EXT READ SECTOR(S) READ SECTOR(S) EXT READ VERIFY SECTOR(S) READ VERIFY SECTOR(S) EXT RECALIBRATE SECURITY DISABLE PASSWORD SECURITY ERASE PREPARE SECURITY ERASE UNIT SECURITY FREEZE LOCK SECURITY SET PASSWORD SECURITY UNLOCK SEEK SET FEATURES SET MAX SET MAX ADDRESS EXT SET MULTIPLE MODE SLEEP SMART STANDBY STANDBY IMMEDIATE WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Code E5h B1h 90h E7h EAh ECh E3h E1h 00h 91h E4h C8h or C9h 25h 60h 2Fh C4h 29h F8h 27h 20h or 21h 24h 40h or 41h 42h 10h F6h F3h F4h F5h F1h F2h 7xh EFh F9h 37h C6h E6h B0h E2h E0h SC O X X X X X O X F O X O O O O O O X X O O O O X X X X X X X X O O O O X X X X Revision 1.00 SN X X X X X X X X F X X O O O O O O X X O O O O X X X X X X X X X O O X X X X X Parameters Used CY DR X O X O X O X O X O X O X O X O F O X O X O O O O O O O O O O O O O X O X O O O O O O O O O X O X O X O X O X O X O X O O O X O O O O O X O X O O O X O X O HD X X X X X X X X X O X O O O O O O X X O O O O X X X X X X X O X O O X X X X X 8 FT X O X X X X X X O X X X X O O X X X X X X X X X X X X X X X X O O X X X O X X Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series WRITE BUFFER E8h WRITE DMA CAh or CBh WRITE DMA EXT 35h WRITE DMA FUA EXT 3Dh WRITE FPDMA QUEUED 61h WRITE LOG EXT 3Fh WRITE MULTIPLE C5h WRITE MULTIPLE EXT 39h WRITE MULTIPLE FUA EXT CEh WRITE SECTOR(S) 30h or 31h WRITE SECTOR(S) EXT 34h WRITE VERIFY 3Ch Note: O = Valid, X = Don’t care SC = Sector Count Register SN = Sector Number Register CY = Cylinder Low/High Register DR = Device Select Bit (Device/Head Register Bit 4) HD = Head Select bit (Device/Head Register Bit 3-0) FT = Features Register 3.2 X O O O O O O O O O O O X O O O O O O O O O O O X O O O O O O O O O O O O O O O O O O O O O O O X O O O O O O O O O O O X X X X O X X X X X X O SMART Command Support The J5 series SSD DOM supports basic SMART command Set used to define some vendor-specific data to report spare/bad block numbers in each memory management unit. Table 11: SMART Command Set Value D0h D2h D8h DAh 3.2.1 Command Read Data attributes Enable/Disable attribute autosave Enable SMART operation Smart Return Status Value D1h D3h D9h Command Read attribute Threshold Save attribute Values Disable SMART operation SMART Attribute Sector The following 512 bytes defines the SMART format. Users can obtain the data using the “Read Data” command. Table 12: SMART Attribute Data Structure Byte 0-1 2-13 14-361 362 363 364-365 366 367 368-369 370 371 Description Data Structure revision number 1st attribute data 2nd-30th Individual attribute data Off-line data collection status Self-test execution status Total time in seconds to complete off-line data collection Reserved Off-line data collection capability SMART capability Error logging capability Self-test failure checkpoint WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 9 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series 372 373 374-510 511 Short self-test routine recommended polling time (in minutes) Extended self-test routine recommended polling time (in minutes) Reserved Data structure checksum 3.2.2 Supported SMART Attributes The following table summarizes the SMART attribute Menu. Table 13: SMART Attribute Menu Summary ID 1 2 3 5 7 8 9 Hex 01h 02h 03h 05h 07h 08h 09h Attribute Name Read Error Rate Throughput Performance Spin up time Reallocated Sector Count Seek Error Rate Seek Time Performance Power-On hours Count 10 12 168 170 173 175 192 194 197 240 0Ah 0Ch A8h AAh ADh AFh C0h C2h C5h F0h Spin Retry Count Device Power Cycle Count SATA PHY Error Count Bad Block Count Erase Count Bad Cluster Table Count Unexpected power Loss Count Temperature Current Pending Sector Count Write Head WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 10 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series 4.0 Physical Specifications SIDE BOTTOM TOP Figure 2: Physical Dimensions Table 14: Physical Specifications Symbol A B C D E F T (Thickness) Min 33.08 31.92 3.56 18.06 9.01 13.99 6.12 Common Dimensions (mm) Nom 33.10 31.95 3.57 18.08 9.00 14.00 6.15 WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 Max 33.12 31.98 3.58 18.10 9.02 14.01 6.18 11 Wintec SATA DOM WxDMxxxG1TC-J51xx (J5) Series 5.0 Ordering Information Table 15: Product Availability List & Naming Model Number W7DM001G1TC-J51yyy-zzz.aa W7DM002G1TC-J51yyy-zzz.aa WxDM004G1TC-J51yyy-zzz.aa WxDM008G1TC-J51yyy-zzz.aa WxDM016G1TC-J51yyy-zzz.aa WxDM032G1TC-J51yyy-zzz.aa WxDM064G1TC-J51yyy-zzz.aa WxDM128G1TC-J51yyy-zzz.aa (x) Flash Type 7: SLC Flash 2: MLC Flash (yyy) Flash IC Manufacturer, Die Revision, Process P: Samsung M: M-die 3:3x nm I: Intel A: A-die 2:2x nm M: Micron B: B-die NAND Flash Type SLC SLC SLC/MLC SLC/MLC SLC/MLC SLC/MLC SLC/MLC SLC/MLC User Capacity 0.94GB 1.9GB 2.8GB 6.5 GB 14 GB 29 GB 59 GB 118 GB (zzz) Component Flash Configuration 002: 2-Nand, Single Die Package, 1-CE 02D: 2-Nand, Dual Die Package, 1-CE 2D2: 2-Nand, Dual Die Package, 2-CE 2Q2: 2-Nand, Quad Die Package, 2-CE (aa) Firmware Options .01 : version 1 Please contact the factory for the latest firmware revisions and/or custom labeling and programming identification. Contact Us (US & Int’l): Wintec Industries OEM Sales 675 Sycamore Drive Milpitas, CA 95035 Ph: 408-856-0500 Fax: 408-856-0501 oemsales@wintecind.com http://www.wintecind.com/oem About Wintec Industries, Inc.: Wintec Industries, founded in 1988, is headquartered in Milpitas, California. Wintec, an ODM/OEM solution provider, specializes in product designs and manufacturing, including Flash modules (CF, SD, USB, embedded Flash, SSD, etc), DRAM modules (RDIMM, SODIMM, UDIMM), wireless products, modem products (embedded and USB), Advanced Digital Display products (ADD2 DVI, HDMI, digital signage), and so on. With experienced engineering team in Silicon Valley, Wintec provides a wide range of services and solutions for customers. Wintec is ISO9001-2000 certified. Important Notice: Wintec Industries makes no representations or warranties with respect to the contents of this datasheet and specifically disclaims any implied warranties of any product design for any particular purpose. Wintec Industries reserves the rights to revise this publication and to make changes from time to time in the content hereof without obligation of Wintec Industries to notify any person or organization of such revisions or changes. WintecSSD-WxDMxxxG1TC-J51xx_v1.0.doc Jan 2012 © Wintec Industries, Inc. Revision 1.00 12
W2DM032G1TC-J51MA2-2D2.01 价格&库存
很抱歉,暂时无法提供与“W2DM032G1TC-J51MA2-2D2.01”相匹配的价格&库存,您可以联系我们找货
