W2SS128G1TC-J21MA2-8D2.A1
    WINTECINDUSTRIES
    SSD 128GB 2.5"
W2SS128G1TC-J21MA2-8D2.A1 数据手册
Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series Wintec Solid State Drive 1.8” SATA II WxSSxxxG1TC-J2xx (J2) Series INFORMATION IN THIS DOCUMENT IS PROVIDED IN RELATION TO WINTEC INDUSTRIES PRODUCTS, AND IS SUBJECT TO CHANGE WITHOUT NOTICE. NOTHING IN THIS DOCUMENT SHALL BE CONSTRUED AS GRANTING ANY LICENSE, EXPRESS OR IMPLIED. ALL INFORMATION IN THIS DOCUMENT IS PROVIDED ON AN “AS-IS” BASIS WITHOUT GUARANTEE OR WARRANTY OF ANY KIND.  Please contact your nearest Wintec representative for the latest updates or additional product information. WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 1 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series Revision History Revision Month Year 0.99 March 2012 WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. History Preliminary Release Revision 0.99 2 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series Table of Contents 1.0 General Product Specification ............................................................................... 5 Block Diagram ............................................................................................................................ 6 Architecture ................................................................................................................................ 6 Flash cell wear leveling ................................................................................................................ 6 Error correction and data integrity ................................................................................................. 6 TRIM support .............................................................................................................................. 6 1.1 1.2 1.3 1.4 1.5 2.0 Electrical Specification .......................................................................................... 7 General ....................................................................................................................................... 7 SATA Pin Assignment and Description ......................................................................................... 7 2.1 2.2 3.0 Software Interface ................................................................................................. 8 3.1 3.2 4.0 5.0 ATA Command Set...................................................................................................................... 8 SMART Command Support ........................................................................................................ 9 Physical Specifications ......................................................................................... 13 Ordering Information.......................................................................................... 14 WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 3 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series Wintec Solid State Drive WxSSxxxG1TC-J2xx Series Features: GENERAL  Density up to 256GB  JMicron 612 controller with external SDRAM buffer  SATA-II/I backwards compatible (3Gbps/1.5Gbps)  High-Performance SLC or MLC NAND Flash memory PERFORMANCE  High Performance 190MB/s Seq. Read (SATA-II)*  High Performance 110MB/s Seq. Write (SATA-II)*  Random Read: 10,000 IOPS at 4KB transfer (SATA-II) RELIABILITY  Data Integrity under power cycling  BCH ECC correction supports 16/24 bit ECC  Enhanced endurance by dynamic/static wear leveling  MTTF: 2,000,000 operating hours. Wintec Solid State Drive NOTE: See Section 5.0 for Configuration & Ordering Guide COMPATIBILITY  Serial ATA Revision 2.6 Compliant  ATA/ATAPI-7 Compliant  Supports TRIM and S.M.A.R.T command Description: The Wintec Industries WxSSxxxG1TC-J2xx series of ROHS Compliant 1.8” uSATA Solid State drives are constructed with NAND-type flash memory devices paired to JMicron JMF612 SSD controller for virtual-to-physical address mapping and other sophisticated flash management functions. The Wintec Flash Solid State Disk (SSD) provides major advantages over the traditional magnetic hard disk drive (HDD). Faster access time and transfer rate, silent operation and low power consumption, better shock and vibration resistance, and lower total cost of ownership make the Wintec SSDs an attractive choice as the next generation mass storage device. The Wintec 1.8” J2 series uSATA SSD provides high-speed data transfer and reliability utilizing SLC or MLC NAND flash in storage capacities ranging from 32GB to 256GB, in a small 1.8” hard drive form factor. Its robust design enables the SSD to achieve highest reliability and performance. The JMF612 controller implements bad block management and dynamic/static wear-leveling techniques to ensure that the NAND flash memory is not worn out prematurely. The drive supports 24 bits/1K Byte sector BCH ECC algorithm for error correction. The drive supports basic S.M.A.R.T features to monitor the drive status and TRIM command to efficiently maintain the data. The Wintec J2 series SSD drives are ideal for notebooks and embedded computing systems that need performance and reliability. *Performance may vary based on drive configuration/NAND Flash type/capacity/test method used for testing. WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 4 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series 1.0 General Product Specification For all the following specifications, values are defined at ambient temperature unless otherwise stated. Table 1: User Capacity Specifications Model Number¹ (typ)2,3 NAND Flash Type MLC W2SS032G1TC-J21xxx-yyy.zz MLC W2SS064G1TC-J21xxx-yyy.zz MLC W2SS128G1TC-J21xxx-yyy.zz NAND Flash Total Capacity 32 GB 64 GB 128 GB Over-provison 7% 7% 7% NOTE: 1. See Section 4.0 for Configuration & Ordering Guide 2. 1GB = 1,000,000,000 Bytes 3. Capacity available to end-user is less than “Total Capacity” due to flash controller overhead, and may vary with flash configuration. Table 2: Typical Performance Specifications Parameter Sustained Sequential Read Sustained Sequential Write Sustained IOPS Random Read Typical Performance4 up to 190 MB/sec (SATA-II) up to 110 MB/sec (2CE)/ 60MB/sec (1CE) (SATA-II) 10,000 IOPS (SATA-II) NOTE: 4. Bandwidth measured on high-performance desktop system. Note that performance may also vary depending on host system, drive capacity, and drive configuration. Measured at QD=32. Table 3: Flash Endurance Parameter Spec up to 70,000 cycles for SLC up to 3,000 cycles for MLC 5 Years (Min.) 2,000,000 Hours Program/Erase Cycles Data Retention MTTF Table 4: SSD Data Reliability Parameter Non-Recoverable Errors Raw ECC Correctability Table 5: Environmental Specifications Parameters Commercial Temp. Temperature Industrial Temp. Humidity (Non-Condensing) Vibration Shock (Operating) Noise WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Spec < 1 in 1016 Bytes Read Up to 24 bits / 1K Bytes data Operating 0C to 70C -40C to 85C 5% to 95% 20 G RMS 1,500 G (Max.) 0 dB Revision 0.99 Non-Operating -55C to 95C -55C to 95C 5% to 95% N/A 0 dB 5 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series 1.1 Block Diagram SATA II PHY Flash Controller 1 & ECC Engine SATA Controller BUS SATA II I/F CPU DRAM Controller Flash Controller 4 & ECC Engine Channel 1 SLC/MLC NAND FLASH Channel 2 SLC/MLC NAND FLASH Channel 3 SLC/MLC NAND FLASH Channel 4 SLC/MLC NAND FLASH Channel 5 SLC/MLC NAND FLASH Channel 6 SLC/MLC NAND FLASH Channel 7 SLC/MLC NAND FLASH Channel 8 SLC/MLC NAND FLASH Figure 1. Block Diagram 1.2 Architecture The Wintec 1.8” J2 series uSATA SSD utilizes a flash controller chip with 8 parallel channels of flash memory interface. The flash controller also simultaneously manages the file read and write interface with the host system via a single SATA-II interface. By utilizing 8 parallel channels of MLC flash memory, the Wintec SSD can provide both high performance and reliability, while maintaining a minimal unit cost. 1.3 Flash cell wear leveling The SSD controller tracks the number of PE (program/erase) cycles that each block in the SSD goes through, and will dynamically remap logical sectors written from the host to different physical pages and blocks within the NAND flash. This including with static wear leveling ensures the flash cells wear evenly, and no premature wear out or data loss will occur in any portions of the drive. 1.4 Error correction and data integrity The drive supports BCH error correction code; the controller can correct 16 bits or 24 bits per 1024 byte data. 1.5 TRIM support The D4 series SSD supports the TRIM command. Data that has been deleted from the host can be marked as free space by the host issuing the TRIM command to the drive. This allows the drive to more efficiently reclaim free space and maintain performance. WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 6 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series 2.0 Electrical Specification 2.1 General Table 6: Absolute Maximum Ratings Symbol VCC Parameter VCC With Respect to GND Min -0.5 Max Units 6.0 V Max 5.5 70 95 Units V C % Table 7: Typical Operating Conditions (VCC=5V  10%) Symbol VCC TA H Parameter VCC With Respect to GND Operating Temperature (Commercial Temp) Humidity Min 4.5 0 5 Table 8: Power consumption Symbol Parameter Value Idle Power consumption 0.95 Pi Typical operating power consumption 1.50 PT Maximum operating power consumption 2.50 Pmax Power measurements were taken under IOMeter06 stress load with 4KB aligned reads and writes 2.2 Units Watts Watts Watts SATA Pin Assignment and Description The SATA connectors are compliant with standard SATA power specifications. As is standard, power may be supplied to all of the power pins. However, only the 5V power pins are utilized to provide power to the SSD. Therefore, where non-standard power supplies and connections are utilized, the power supply does not need to supply the SSD with power to the 3.3V power pins. Table 9: SATA connector specification compliant No. Signal Plug Connector pin definition S1 GND S2 A+ S3 A- S4 GND S5 B- S6 B+ S7 GND Ground Differential signal A Ground Differential signal B Ground Key and spacing separate signal and power segments Power P1 V33 3.3V power (Not Used) P2 V33 3.3V power (Not Used) P3 GND Ground P4 GND Ground WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 7 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series P5 V5 5V power P6 V5 5V power P7 Rev Not used P8 Optional Not used P9 Optional Not used 3.0 Software Interface 3.1 ATA Command Set All mandatory, and many optional commands and features are supported. The following tables summarize the ATA feature set and commands. Table 10: ATA Command Command Name CHECK POWER MODE EXECUTE DIAGNOSTICS FLUSH CACHE IDENTIFY DEVICE IDLE IDLE IMMEDIATE INITIALIZE DEVICE PARAMETERS READ DMA READ MULTIPLE READ SECTOR(S) READ VERIFY SECTOR(S) RECALIBRATE SECURITY DISABLE PASSWORD SECURITY ERASE PREPARE SECURITY ERASE UNIT SECURITY FREEZE LOCK SECURITY SET PASSWORD SECURITY UNLOCK SEEK SET FEATURES SET MULTIPLE MODE SLEEP SMART STANDBY STANDBY IMMEDIATE WRITE DMA WRITE MULTIPLE WRITE SECTOR(S) WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Code E5h 90h E7h ECh E3h E1h 91h C8h or C9h C4h 20h or 21h 40h or 41h 10h F6h F3h F4h F5h F1h F2h 7xh EFh C6h E6h B0h E2h E0h CAh or CBh C5h 30h or 31h SC O X X X O X O O O O O X X X X X X X X O O X X X X O O O Revision 0.99 SN X X X X X X X O O O O X X X X X X X X X X X X X X O O O Parameters Used CY DR X O X O X O X O X O X O X O O O O O O O O O X O X O X O X O X O X O X O O O X O X O X O O O X O X O O O O O O O HD X X O X X X O O O O O X X X X X X X O X X X X X X O O O 8 FT X X X X X X X X X X X X X X X X X X X O X X O X X X X X Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series Note: O = Valid, X = Don’t care SC = Sector Count Register SN = Sector Number Register CY = Cylinder Low/High Register DR = Device Select Bit (Device/Head Register Bit 4) HD = Head Select bit (Device/Head Register Bit 3-0) FT = Features Register 3.2 SMART Command Support 3.2.1 SMART Function Set (B0h) The J2 series express card performs different processing required for predicting device failures, according to the subcommand specified in the feature register. If the feature register contains an unsupported value, the aborted command error is returned. If the SMART function is disabled, any subcommand other than SMART enable operations results in the aborted command error. Table 11: SMART Function Set (B0h) Value Command Read Data attributes D0h Enable/Disable attribute auto save D2h Execute Off-line Immediate D4h Write log D6h Disable SMART operation D9h Enable/Disable Auto Off-line DBh 3.2.2 Value D1h D3h D5h D8h DAh Command Read attribute Threshold Save attribute Values Read log Enable SMART operation Return Status SMART Read Data (B0h/D0h) This command returns 512-byte SMART data structure to the host with PIO data-in protocol. The register file has to contain D0h for features register, 4Fh for LBA mid register and C2h for the LBA high register. Table 12: SMART Attribute Data Structure Byte Description Data Structure revision number 0-1 1st attribute data 2-13 2nd-30th Individual attribute data 14-361 Off-line data collection status 362 Self-test execution status 363 Total time in seconds to complete off-line data collection 364-365 Reserved 366 Off-line data collection capability 367 SMART capability 368-369 Error logging capability 370 Self-test failure checkpoint 371 Short self-test routine recommended polling time (in minutes) 372 Extended self-test routine recommended polling time (in minutes) 373 Reserved 374-510 Data structure checksum 511 WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 9 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series Table 13: Byte 2-361 Individual attribute data Byte Description Attribute ID 0 Status Flag 1-2 Attribute Value 3 Worst ever normalized attribute value 4 Raw attribute value 5-10 Reserved 11 3.2.3 SMART Attribute ID The following table summarizes the SMART attribute ID information. Table 13: SMART Attribute Menu Summary ID Hex Attribute Name 1 01h Read Error Rate 2 02h Throughput Performance 3 03h Spin up time 5 05h Reallocated Sector Count 7 07h Seek Error Rate 8 08h Seek Time Performance 9 09h Power-On hours Count 10 12 168 170 173 175 192 194 197 240 3.2.4 0Ah 0Ch A8h AAh ADh AFh C0h C2h C5h F0h Spin Retry Count Device Power Cycle Count SATA PHY Error Count Bad Block Count Erase Count Bad Cluster Table Count Unexpected power Loss Count Temperature Current Pending Sector Count Write Head SMART Read Attribute Threshold (B0h/D1h) This command transfers 512 bytes of drive failure threshold data to the host. Byte 0-1 2-361 362-510 511 3.2.5 Description Data structure revision number 1st- 30th individual attribute threshold data Reserved Data structure checksum SMART Enable/Disable Attribute Auto save (B0h/D2h) WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 10 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series This command enables and disables the optional attribute autosave feature of the device. This command may either allow the device, after some vendor specified event, to save the device updated attributes to non-volatile memory; or this command may cause the autosave feature to be disabled. The state of the attribute autosave feature, either enabled or disabled, shall be preserved by the device during all power and reset events. A value of zero written by the host into the devices count field before issuing this command shall cause this feature to be disabled. Disabling this feature does not preclude the device from saving SMART data to no-volatile memory during some other normal operation (e.g., during a power-on or power-off sequence or during an error recovery sequence). A value of F1h written by the host into the device’s count field before issuing this command shall cause this feature to be enabled. Any other non-zero value written by the host into this field before issuing this command is vendor specific. The meaning of any non-zero value written to this field at this time shall be preserved by the device during all power and reset events. 3.2.6 SMART Enable/Disable Attribute Auto save (B0h/D2h) Saves any modified attribute values 3.2.7 SMART Execute Off-line Immediate (B0h/D4h) This command of non-data input causes the controller to immediately initiate the set of activities that collect SMART data in off-line mode and then save data to the NAND flash memory, or execute a self-diagnostic test routine in either captive or off-line mode. Byte 0 1 2 127 129 130 3.2.8 Description of subcommand to be executed Execute SMART off-line routine immediately in off-line mode Execute SMART Short self-test routine immediately in off-line mode Execute SMART extended self-test routine immediately in off-line mode Abort off-line mode self-test routine Execute SMART Short self-test routine immediately in captive mode Execute SMART extended self-test routine immediately in off-line mode SMART Read Log (B0h/D5h) This command returns the indicated log sector contents to the host. Sector count specifies the number of sectors to be read from the specified log. The log transferred by the drive shall start at the first sector in the specified log, regardless of the sector count requested. Sector number indicates the log sector to be returned as described in the following Table. Value 0 1 2 3 Content Execute SMART off-line routine immediately in off-line mode Execute SMART Short self-test routine immediately in off-line mode Execute SMART extended self-test routine immediately in off-line mode Abort off-line mode self-test routine WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 R/W RO RO RO RO 11 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series 6 7 128-159 3.2.9 Execute SMART Short self-test routine immediately in captive mode Execute SMART extended self-test routine immediately in off-line mode Host vendor specific RO RO R/W SMART Write Log (B0h/D6h) This command writes as indicated number of 512 byte data sectors to the indicated log (Host vendor specific). 3.2.10 SMART Enable Operations (B0h/D8h) Enables the SMART function; this setting is maintained when the power is turned off and then back on. Once the SMART function is enabled, subsequent SMART ENABLE OPERATIONS commands do not affect any parameters. 3.2.11 SMART Disable Operations (B0h/D9h) Disables the SMART function; upon receiving the command, the drive disables all SMART operations. This setting is maintained when the power is turned off and then back on. Once this command has been received, all SMART commands other than SMART ENABLE OPERATIONS are aborted with the aborted Command error. This command disables all SMART capabilities including any and all timer and event count functions related exclusively to this feature. After command acceptance, this controller will disable all SMART operations. SMART data in no longer be monitored or saved. The state of SMART is preserved across power cycles. 3.2.12 SMART Return Status (B0h/DAh) Reports the drive reliability status; Values reported when a predicted defect has not been detected: Cylinder Low register: 4Fh Cylinder High register: C2h Values reported when a predicted defect has been detected: Cylinder Low register: F4h Cylinder High register: 2Ch 3.2.13 SMART Enable/Disable Automatic Off-line (B0h/DBh) Enables (when Sector Count register = “F8h”) or disables (Sector Count register = “00h”) the automatic off-line data collection function. The automatic collection is disabled if a value of “00h” is set in the Sector Count register before a subcommand is issued. If automatic collection is disabled, the drive can still save attribute information during normal operation, such as during the power-on/off sequence or error correction sequence. The automatic collection function is enabled if a value of “F8h” is set in the Sector Count register before the command is issued. Values other than “00h” and “F8h” are vendor-specific. WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 12 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series 4.0 Physical Specifications Table 15: Physical Specifications Weight: Length: Width: Thickness: 3.0 oz typical 78.5 mm 54.0 mm 5.0 mm Figure 2: Physical Dimensions WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 13 Wintec 1.8” Solid State Drive WxSSxxxG1TC-J2xx (J2) Series 5.0 Ordering Information Table 16: Product Availability List & Naming Model Number¹ W2SS032G1TC-J21xxx-yyy.zz W2SS064G1TC-J21xxx-yyy.zz W2SS128G1TC-J21xxx-yyy.zz (u) NAND Flash Type Overprovision MLC MLC MLC Flash Type 7: SLC Flash 2: MLC Flash 7% 7% 7% User Capacity (typ)2,3 30 GB 60 GB 120 GB (yyy) Component Flash Configuration 008: 8-Nand, Single Die Package, 1-CE 08D: 8-Nand, Dual Die Package, 1-CE 8D2: 8-Nand, Dual Die Package, 2-CE 8Q2: 8-Nand, Quad Die Package, 2-CE (xxx) Flash IC Manufacturer, Die Revision, Process P: Samsung M: M-die 3:3x nm I: Intel A: A-die 2:2x nm M: Micron B: B-die T: Toshiba C: C-die (zz) Firmware Revision/Options Please contact the factory for the latest firmware revisions and/or custom labeling and programming identification. Contact Us (US & Int’l): Wintec Industries OEM Sales 675 Sycamore Drive Milpitas, CA 95035 Ph: 408-856-0500 Fax: 408-856-0501 oemsales@wintecind.com http://www.wintecind.com/oem About Wintec Industries, Inc.: Wintec Industries, founded in 1988, is headquartered in Milpitas, California. Wintec, an ODM/OEM solution provider, specializes in product designs and manufacturing, including Flash modules (CF, SD, USB, embedded Flash, SSD, etc), DRAM modules (RDIMM, SODIMM, UDIMM), wireless products, modem products (embedded and USB), Advanced Digital Display products (ADD2 DVI, HDMI, digital signage), and so on. With experienced engineering team in Silicon Valley, Wintec provides a wide range of services and solutions for customers. Wintec is ISO9001-2000 certified. Important Notice: Wintec Industries makes no representations or warranties with respect to the contents of this datasheet and specifically disclaims any implied warranties of any product design for any particular purpose. Wintec Industries reserves the rights to revise this publication and to make changes from time to time in the content hereof without obligation of Wintec Industries to notify any person or organization of such revisions or changes. WintecSSD-WxSSxxxG1TC-J2xx_v099.doc March 2012  Wintec Industries, Inc. Revision 0.99 14
W2SS128G1TC-J21MA2-8D2.A1 价格&库存
很抱歉,暂时无法提供与“W2SS128G1TC-J21MA2-8D2.A1”相匹配的价格&库存,您可以联系我们找货
