SMS15PD3
SMS15PD3
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN PLUG HSG 15POS 5.08MM
SMS15PD3 数据手册
c ; 0+ ; IW 3,27 A B C D E F G H B Discrimination cavity Contact cavity C B 3,6 4 4 Material : 32.7 ± 0.3 POLYAMIDE PA 6 / UL94-V0 / COLOUR : GREY I3F2 in accordance with NF F 16101 and NF F 16102 standard 3 B Operating temperature : -40°C to 105°C Insulation resistance : 5000M Ohm Min. Test potential : 2000 VAC Durability : 500 Cycles 19,68 D 3 Performance characteristics : NOTA : 33.7 Max Dimensions in mm Quantity of Contact cavities Quantity of discrination cavities SMS2PD3 2 0 16.4 8.4 14.1 14.9 SMS3PD3 3 0 16.4 8.4 18.6 19.4 2 Catalog Number SMS4PD3 4 0 B ± 0.5 C ± 0.3 D ± 0.3 16.4 8.4 24 F 1 6 2 21.5 13.7 19.1 19.9 SMS9PD3 9 4 26.7 18.5 18.6 19.4 SMS12PD3 12 6 31.7 23.9 18.6 19.4 SMS15PD3 15 8 36.7 29 18.6 19.4 SMS18PD3 18 10 41.8 34.1 18.9 19.4 SMS24PD3 24 15 41.8 34.1 24 24.8 SMS36PD3 36 24 31.7 23.9 49.4 50.2 G F E 2 P/N : SMSXXPD3 -- 24.8 SMS6PD3 H 1- Connector accepts TRIMTRIO formed,machined and subminiature coaxial pin and socket contacts. 2- Raised contact marking on both : mating and wiring face. 3- Discrimination with pins is guaranteed without loss of contact positions. If discrimination pins are needed : order SMSPKE3 per BS.C.201424.003. 5- For the configuration of all sizes see drawinf : BS.C.201424.007 6- For intermateability with other parts see drawing : BS.C.201424.008 c 22/04/14 ISS DATE Designed by: TITLE Update drawing ; add detail and F dimension Latest modification - by: ROUILLARD ROUILLARD Date:28/03/08 -MOD N° CUSTOMER DRAWING QIKMATE PLUG WITHOUT MOULDED-ON HOOD AND DISC.CAV SMS CONNECTOR Scale General linear Tolerances: ± 0.2 2/1 NPRDS / PROJECT TRIMTRIO WWW.SOURIAU.COM SOURIAU DRG N° FORMAT D A3 1 This document is the property of SOURIAU It must not be reproduced or communicated without permission C BSC201424016 B SHEET 1/1 A
SMS15PD3 价格&库存
很抱歉,暂时无法提供与“SMS15PD3”相匹配的价格&库存,您可以联系我们找货
