SMS6GE6T
SMS6GE6T
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN HEADER R/A 6POS 5.08MM
SMS6GE6T 数据手册
A B C D E F G H I J K L M N O P a ; 0 ; RL DIAMETER MALE CONTACT 3.5 24.2 110 U 220V AC according to NFF 61030 WITHSTAND VOLTAGE 2 550V AC according to NFF 61030 CREEPAGE DISTANCE CLEARANCE 2.5 mm 2.5 mm RATED CURRENT FOR THE CONNECTOR WITH ALL CONTACTS 24.5 8 7.5 A >4000 M INSULATION RESISTANCE CONTACT RESISTANCE ENVIRONMENTAL CHARACTERISTICS 14.4 24.2 5,08 5,08 1.2 20.5 16,5 ELECTRICAL CHARACTERISTICS 16.2 Maxi 1.2 14.4 RATED VOLTAGE 3.5 19 8 16.2 Maxi 1.6 mm < OU = 2.5 m CLIMATIC RANGE PROTECTION DEGREE (CONNECTOR MATED) 40/100/21 IP30 FIRE BEHAVIOUR I2F3 7 CORROSION BEHAVIOUR TEMPERATURE RANGE ROHS COMPLIANT 96 H -40 / +100°C OUI 7 MECHANICAL CHARACTERISTICS 5,08 24.2 24.2 3.4 30,2 3.4 30,2 11.9 6.8 2.5 2.5 6 4 4,5 2 See Nota (Number of descrimination position =2) Ø0,8 Mark 1 (3 Contacts) Mark 2 (6 Contacts) 21.2 Maxi 1 5,08 4,5 5 16.5 MATING FORCE INSULATOR RETENTION FORCE N/A CONTACTS RETENTION FORCE >15N CONTACTS PROTECTION (SCOOP PROOF) 50% 6 NOTA : Descrimination option : See drawing BS.C.201424.003 3 Ø0,8 VERSION 3 POINTS - 6,5 N VERSION 6 POINTS - 13,5 N VERSION 12 POINTS - 27 N VERSION 18 POINTS - 40 N Mark 16.5 3,5 SMS18GE63 SMS18GE53 SMS12GE63 SMS12GE53 SMS6GE63 SMS6GE53 SMS3GE63 SMS3GE53 MALE RECEPTACLE - 18 POINTS FEMALE RECEPTACLE - 18 POINTS MALE RECEPTACLE - 12 POINTS FEMALE RECEPTACLE - 12 POINTS MALE RECEPTACLE - 6 POINTS FEMALE RECEPTACLE - 6 POINTS MALE RECEPTACLE - 3 POINTS FEMALE RECEPTACLE - 3 POINTS 18 12 6 3 P/N Layout RECEPTACLE = POLYAMID PA 6.6 CONTACTS (See "table contacts) RECEPTACLE = POLYAMID PA 6.6 CONTACTS (See "table contacts) RECEPTACLE = POLYAMID PA 6.6 CONTACTS (See "table contacts) Designation PART NUMBER'S EXAMPLE SMS 6 GE Material 5 3 Weight (grs) 5 CONTACTS (Already mounting) SMS CONNECTORS Layout Solid machined contacts "5" -->Female contact "6" -->Male contact Specif. =Fire Behaviour 3.5 21.5 21.5 15.5 15.5 8 8 4 4 RECEPTACLE = POLYAMID PA 6.6 CONTACTS (See "table contacts) 10 9 8 PIN BRASS 0.6 0.6 0.6 7 6 5 SOCKET BRASS 0.6 0.6 0.6 Mark Designation Material Weight (grs) 31,2 Maxi 4 1.2 MALE CONNECTORS "6" FEMALE CONNECTORS "5" 21,6 39,4 29,5 29.2 29,5 5,08 14.4 21,6 14,38 4 1.2 3 5,08 3 3.4 Ø3.4 29.2 5.08 39,4 7±0,35 45,4 5.08 Ø0.8 7 6 4.5 4.5 35,2 Ø0.8 5 10 9 8 2.5 17,2 2 2 New drawing 2.5 17,2 a 04/07/11 ISS DATE Designed by: Ø0,8 16,5 5,08 1 Ø0,8 Mark 4 (18 Contacts) N M L Date:04/07/11 SORIN V. MOD N° CUSTOMER DRAWING BORDMOUNT QIKMATE General linear Tolerances: ± 0.5 3/1 Mark 3 (12 Contacts) O SORIN V. Scale See Nota (Number of descrimination position =6) P __ Latest modification - by: RIGHT ANGLE BOARDMOUNT WITH CONTACTS K J 4.5 4.5 TITLE __ See Nota (Number of descrimination position =10) I 5,08 16,5 G __ WWW.SOURIAU.COM F E D A1 1 This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° FORMAT H NPRDS / PROJECT C SMS-XX-GE53-GE63-C B SHEET 1/1 A
SMS6GE6T 价格&库存
很抱歉,暂时无法提供与“SMS6GE6T”相匹配的价格&库存,您可以联系我们找货
