PNS1/2 BK080
PNS1/2 BK080
    ALPHAWIRE(阿尔法电线)
    CABLE GLAND 6-12MM 1/2NPT POLY
PNS1/2 BK080 数据手册
ALPHA WIRE COMPANY CUSTOMER PRODUCT SPECIFICATION Part Numbers: PMS3/8-PMS3/4 Spec Number: PMS NPT Page 1 of 1 Pages Issue: Issue Date: Effective Date: A. Technical Details 1) Material a) Body b) Cap c) Seal 2) Color a) Gray, RAL 7001 3) Protection Class a) IP 68 b) IP 66 4) Flammability a) V2 5) Temperature Rating a) Permanent b) Intermittent 6) Thread Type a) b) 7) Approvals a) UL b) CSA 1 11/01/2017 11/13/2017 PA 6 (Polyamide 6) PA 6 (Polyamide 6) CR (Chloroprene Rubber) 5 Bar, 30 min (According to UL94) -20°C to +100°C -30°C to +150°C UL 514 CSA C22.2 Thread Length TL mm inch 15,0 0.591 Thread Ø TD mm inch 17,14 0.673 Spanner Width SW CAP SW BODY mm Inch mm Inch 22 0.866 22 0.866 Outer Ø D mm inch 25,3 0.996 Max. Height H mm inch 81,5 3.169 Part Number NPT-3/8" Clamping Range Ø min-max mm inch 5,0-10,0 0.197-0.394 NPT-1/2" 6,0-12,0 0.236-0.472 15,0 0.591 21,34 0.839 24 0.945 24 0.945 27,6 1.087 93,3 3.72 PNS1/2 NPT-3/4" 13,0-18,0 0.512-0.709 15,0 0.591 26,67 1.051 33 1.299 33 1.299 38,0 1.496 117,9 4.606 PNS3/4 Size B. Packaging Requirements 1) Standard Package 10 glands per package Although Alpha Wire ("Alpha") makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. 711 Lidgerwood Ave Elizabeth, NJ 07207-0711 Toll Free 1-800-52 ALPHA • T: 1-908-925-8000 • F: 908-925-5411 • Email: info@alphawire.com www.alphawire.com PNS3/8
PNS1/2 BK080 价格&库存
很抱歉,暂时无法提供与“PNS1/2 BK080”相匹配的价格&库存,您可以联系我们找货
PNS1/2 BK080
  • 1+60.617951+7.58192
  • 10+51.5149310+6.44334
  • 25+48.2835025+6.03916
  • 50+45.9770450+5.75068
  • 100+43.78296100+5.47625
  • 250+41.04191250+5.13341
  • 500+39.08407500+4.88852
  • 1000+37.220191000+4.65540
  • 2500+36.253082500+4.53443
PNS1/2 BK080
    • 1+1.08000
    库存:1
