MOLC-108-02-H-Q-P
MOLC-108-02-H-Q-P
    SAMTEC(申泰)
    CONN HEADER SMD 32POS 1.27MM
MOLC-108-02-H-Q-P 数据手册
REVISIONS 39.5 2xØ3.10±0.12x11.18 DP REV 24.9 RECOMMENDED SCREW: 6-19 [M3.63 x 1.34] THREAD-FORMING SCREW, TORQUE: 11-15 IN-LB [1.24-1.70 NM] 11.4 ECO DESCRIPTION DATE BY APPR A1 -- RELEASE NEW DRAWING 2MAR18 JONY TOMMY A2 -- REVISED DRAWING 10JUL20 JHEAD DH 6.1 4.1 RESERVOIR 3xØ6.6 TITLE: 4.4 PCB MOUNT RECEPTACLE,6PIN,RA FLANGE,AT SERIES 21.7 42.8 32.9 24.2 29.9 22.9 4.4 8 FLANGE SEAL 9.1 PIN SPACER 3xØ2.79±0.12 15.5 AT13-6PX-BMXX 1. MATERIAL: HOUSING: THERMOPLASTIC SEAL:SILICONE RUBBER CONTACT: COPPER ALLOY DWG NO: NOTES: UNLESS OTHERWISE SPECIFIED RECOMMENDED SCREW: 4-20 [M3.12 x 1.27] THREAD-FORMING SCREW, TORQUE:6-10 IN-LB [0.68-1.13 NM] 6.4 6xØ1.58 3.1±0.4 2. MODIFICATIONS: FLANGE;PCB MOUNT,RIGHT ANGLE 38.6 UNLESS OTHERWISE SPECIFIED 1) All dimensions are in metric(mm). 2) Tolerances are as follows: 1 PL DEC ±0.30 Fractions ±1/64 2 PL DEC ±0.15 Angles ±1° 3 PL DEC ±0.08 X SIGNATURES DRAWN: CHECKED: 2MAR18 2MAR18 TOMMY.XIE 2MAR18 Sine Systems - www.amphenol-sine.com 44724 Morley Drive Clinton Township, MI 48036 ENGINEER: APPROVAL: MATERIAL SPECIFICATIONS: CUSTOMER: PROCESS SPECIFICATIONS: Amphenol DATE JONY.XIE ORION.LI BOARDMLOCK PCB MOUNT RECEPTACLE, 6 PIN, RA FLANGE, AT SERIES THIS DRAWING IS SUPPLIED FOR INFORMATION ONLY. DESIGN FEATURES, SPECIFICATIONS AND PERFORMANCE DATA SIZE SHOWN HEREON ARE THE PROPERTY OF THE AMPHENOL CORPORATION. NO RIGHTS OF REPRODUCTION ARE IMPLIED. ALL DIMENSIONS ARE SUBJECT TO NORMAL SCALE: MANUFACTURING VARIATIONS. TYPE B C- NEXT ASS'Y: ITEM NONE DWG NO: REVISION AT13-6PX-BMXX SHEET 1 A2 OF 2 2 REF: DT13-6P, DT13-6P-G003 AT13-6PX-BMXX DESCRIPTION PART NUMBER MATERIALS LIST QUANTITY 3) Note reference = OF: POTTED CONNECTORS SPECIFIED FOR UP TO 5 P.S.I. APPLICATIONS. 20.8 1 6. 35.3 SH: 5. ALL DIMENSIONS ARE FOR REFERENCE USE ONLY. 3.9 A2 4. MATING PART: AT06-6S* PLUG ( * = MODIFICATIONS ) REV: 3. SPECIFICATIONS: 3.1 CURRENT RATING: 13 AMPS 3.2 OPERATING TEMPERATURE: -55°C TO +125°C 3.3 DIELECTRIC WITHSTANDING VOLTAGE: LESS THAN 2 MILLIAMPS CURRENT LEAKAGE @ 1500 VOLTS AC. 3.4 INSULATION RESISTANCE: 1000 MEGOHMS MIN @ 25°C. 3.5 MOISTURE RESISTANCE: IP67 ( MATED CONDITION ) 3.6 MATING CYCLE DURABILITY: 100 CYCLES 3.7 RoHS COMPLIANT REVISIONS REV ECO DESCRIPTION DATE BY APPR A1 -- RELEASE NEW DRAWING 2MAR18 JONY TOMMY A2 -- REVISED DRAWING 10JUL20 JHEAD DH 6P KEYWAY 6P2 KEYWAY TITLE: CONTACT POTTING OR NOT PLATING IN RESERVOIR GOLD TIN 4XR5.59 2XR1.52 NO POTTING POTTING AT13-6P-BM01GRY GOLD AT13-6P-BM02GRY GOLD AT13-6P-BM03GRY TIN AT13-6P-BM04GRY TIN INTERNAL SEALING SURFACE FINISH TO BE 3.2 OR BETTER NO POTTING POTTING NO POTTING POTTING PART NUMBER AT13-6P2-BM01BLU AT13-6P2-BM02BLU AT13-6P2-BM03BLU AT13-6P2-BM04BLU 0.13 REV: 42.80 MIN. POTTING CONTACT POTTING OR NOT PLATING IN RESERVOIR PART NUMBER AT13-6PX-BMXX TIN NO POTTING AT13-6P2-BMXX VARIANTS DWG NO: GOLD PCB MOUNT RECEPTACLE,6PIN,RA FLANGE,AT SERIES AT13-6P-BMXX VARIANTS A2 21.74±0.10 QUANTITY UNLESS OTHERWISE SPECIFIED 2XØ3.94 21.92 4xR7.62 MAX. 3.9 25.17 32.89 RECOMMENDED PANEL CUTOUT 11.43±0.10 8.8 6.35±0.05 1) 2) 1 2 3 All dimensions are in metric(mm). Tolerances are as follows: PL DEC ±0.30 Fractions ±1/64 PL DEC ±0.15 Angles ±1° PL DEC ±0.08 3) Note reference = X SIGNATURES DRAWN: CHECKED: 3XØ3.43 MATERIAL SPECIFICATIONS: CUSTOMER: PROCESS SPECIFICATIONS: 2MAR18 2MAR18 TOMMY.XIE 2MAR18 Sine Systems - www.amphenol-sine.com 44724 Morley Drive Clinton Township, MI 48036 ENGINEER: APPROVAL: 6.10±0.10 Amphenol DATE JONY.XIE ORION.LI BOARDLOCK PCB MOUNT RECEPTACLE, 6 PIN, RA FLANGE, AT SERIES THIS DRAWING IS SUPPLIED FOR INFORMATION ONLY. DESIGN FEATURES, SPECIFICATIONS AND PERFORMANCE DATA SIZE SHOWN HEREON ARE THE PROPERTY OF THE AMPHENOL CORPORATION. NO RIGHTS OF REPRODUCTION ARE IMPLIED. ALL DIMENSIONS ARE SUBJECT TO NORMAL SCALE: MANUFACTURING VARIATIONS. TYPE B C- RECOMMENDED PCB LAYOUT NEXT ASS'Y: ITEM NONE DWG NO: REVISION AT13-6PX-BMXX SHEET 2 A2 OF 2 2 AT13-6PX-BMXX DESCRIPTION PART NUMBER MATERIALS LIST 21.84 11.18 OF: 2XR1.02 6XØ1.80+0.1 0 2 35.47 MIN. SH: 8.84±0.05
MOLC-108-02-H-Q-P 价格&库存
很抱歉,暂时无法提供与“MOLC-108-02-H-Q-P”相匹配的价格&库存,您可以联系我们找货
