2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Check Stock
Request a Sample
Certificate of Origin
Send Us An Email
Generated Part Number
KPCIEX-SM1-36BK
Part Number Builder
KPCIEX
PCI EXPRESS CARD EDGE:
KPCIEX Series
Straddle Mount PCI Express Card Edge
Supports 2.5 Gb/s Data Transfer Rate
(Per Pair Data Bandwidth)
Standard 36, 64, 98,164 Pin
Standard 1.0mm Pitch
Performance Specifications
Materials and Finish
Housing
High Temperature Thermoplastic
Contacts
Phosphor Bronze
Contact Plating
Standard: Gold Flash over 50 Nickel on Contact Area,
100µ" Min. Tin over 50µ" Nickel on Termination End
30: 30µ" Gold over 50µ" Nickel on Contact Area 100µ" Min.
Rated Voltage
50V AC (RMS) / DC
Rated Current
1.1A
Contact Resistance
30 milliohms Max.
Insulation Resistance
1000 Megohms Min.
Dielectric Strength
500V AC RMS for 1 Minute
BK
Mounting
Option
Number
Option
Color
Option
Plating
Option
Series
KPCIEX - Straddle Mount PCI Express Card Edge
Product Features
Electrical Characteristics
Series
36
SM1
Mounting Option
SM1 - Straddle Mount No Peg Option
SM2 - Straddle Mount With Peg Option
SM3 - Straddle Mount With Ear Clips Option
Number of Pins
36 - Pins
64 - Pins
98 - Pins
164 - Pins
Color*
BK - Black Standard
Plating Material*
Blank - Gold Flash Standard
30 - 30µ" Gold
Contact Kycon for Other Options
KPCIEX Series
Dimensions in mm
KPCIEX-SM1
Mechanical Characteristics
Insertion Force
1.15N Max. Per Contact Pair
Extraction Force
0.15N Min. Per Contact Pair
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0815
很抱歉,暂时无法提供与“KPCIEX-SM1-36BK30”相匹配的价格&库存,您可以联系我们找货
