KPCIEX-SM2-64BK30
KPCIEX-SM2-64BK30
    KYCON
    X4, 64 PIN, RIGHT ANGLE, STRADDL
KPCIEX-SM2-64BK30 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Check Stock Request a Sample Certificate of Origin Send Us An Email Generated Part Number KPCIEX-SM1-36BK Part Number Builder KPCIEX PCI EXPRESS CARD EDGE: KPCIEX Series Straddle Mount PCI Express Card Edge Supports 2.5 Gb/s Data Transfer Rate (Per Pair Data Bandwidth) Standard 36, 64, 98,164 Pin Standard 1.0mm Pitch Performance Specifications Materials and Finish Housing High Temperature Thermoplastic Contacts Phosphor Bronze Contact Plating Standard: Gold Flash over 50 Nickel on Contact Area, 100µ" Min. Tin over 50µ" Nickel on Termination End 30: 30µ" Gold over 50µ" Nickel on Contact Area 100µ" Min. Tin over 50µ" Nickel on Termination End Rated Voltage 50V AC (RMS) / DC Rated Current 1.1A Contact Resistance 30 milliohms Max. Insulation Resistance 1000 Megohms Min. Dielectric Strength 500V AC RMS for 1 Minute BK Mounting Option Number Option Color Option Plating Option Series KPCIEX - Straddle Mount PCI Express Card Edge Product Features Electrical Characteristics Series 36 SM1 Mounting Option SM1 - Straddle Mount No Peg Option SM2 - Straddle Mount With Peg Option SM3 - Straddle Mount With Ear Clips Option Number of Pins 36 - Pins 64 - Pins 98 - Pins 164 - Pins Color* BK - Black Standard Plating Material* Blank - Gold Flash Standard 30 - 30µ" Gold Contact Kycon for Other Options KPCIEX Series Dimensions in mm KPCIEX-SM1 Mechanical Characteristics Insertion Force 1.15N Max. Per Contact Pair Extraction Force 0.15N Min. Per Contact Pair Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0815
KPCIEX-SM2-64BK30 价格&库存
很抱歉,暂时无法提供与“KPCIEX-SM2-64BK30”相匹配的价格&库存,您可以联系我们找货
