GAX-8-64
GAX-8-64
    KYCON
    插件
    GANGJACK 8PORT RT< 6P4C GREY ROH
GAX-8-64 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GAX-2-62 Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GAX Series Right Angle Ganged Jack Materials and Finish Housing Material PBT Thermoplastic, UL 94V-0 Rated, Color: Gray Metal Peg: Phosphor Bronze, Tin Plated Contact Material Phosphor Bronze Contact Plating Options Standard 0.0001" Nickel Underplating, Gold Flash Plated overall 50 0.0001" Nickel Underplating, 0.000050" Gold Plated overall to Comply with FCC Requirements Under No. 47 C.F.R. Part 68, Subpart F Electrical Characteristics Current Rating 1.5A Voltage Rating 125V DC Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V AC RMS for 1 Minute Contact Resistance 20 milliohms Max. No. of Positions Plating Option Series GAX - Right Angle PCB Mount Number of Ports 2 - 2 Port 3 - 3 Port 4 - 4 Port 5 - 5 Port (Available Only With 6 Positions) 6 - 6 Port (Available Only With 6 Positions) 7 - 7 Port (Available Only With 6 Positions) 8 - 8 Port (Available Only With 6 Positions) Number of Positions / Contacts 62 - 6 Positions / 2 Contacts 64 - 6 Positions / 4 Contacts 66 - 6 Positions / 6 Contacts 88 - 8 Positions / 8 Contacts Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Contact Kycon for Other Options GAX Series Dimensions in mm 16.00 A±0.25 11.00 (Pitch) 2.50 8.97±0.25 4.60 15.40 Performance Specifications 62 No. of Ports 4.00 Available in 6 and 8 Position Housings Right Angle Version Ribbed Pin Guides Metal Locking Brackets CSA/NRTL Certified File No. LR78160 2 Series 2.50 Product Features GAX 3.25±0.25 2.03 4.5±0.5 For 6 Position Plugs B±0.25 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0621 3.53
GAX-8-64
PDF文档中提到的物料型号为GAX-2-62,属于KYCON公司的MODULAR JACKS AND PLUGS: GAX系列。
该产品具有以下特点:
- 系列编号:GAX - 端口数量:2至8个端口,具体取决于选择的型号 - 引脚数量:2至8个引脚,具体取决于选择的型号 - 外壳材料:PBT热塑性塑料,UL 94V-0等级,颜色为灰色 - 金属销:磷青铜,锡镀 - 接触材料:磷青铜 - 接触镀层选项:标准为0.0001"镍底层镀层,整体金闪镀层;50µ"金镀层以符合FCC要求
电气特性包括: - 电流额定值:1.5A - 电压额定值:125V DC - 绝缘电阻:最小500兆欧 - 介质耐压:1分钟1000V交流峰值 - 接触电阻:最大20毫欧
尺寸信息(单位mm): - A±0.25:16.00 - B±0.25:8.97 - C(间距):11.00 - D:4.60 - E:2.50 - F:4.00 - G:2.50 - H±0.25:15.40 - I±0.25:3.25(对于6位插头为3.53)
此外,文档还提供了2D图纸、IGES、STEP、3D PDF等设计文件的链接,以及UL塑料文件、原产地证书、库存检查、样品请求和电子邮件联系信息。
GAX-8-64 价格&库存
很抱歉,暂时无法提供与“GAX-8-64”相匹配的价格&库存,您可以联系我们找货
GAX-8-64
    • 1+116.69400
    • 200+46.56960
    • 500+45.01440
    • 1000+44.23680
