GDLX-SMT-S-64-50
GDLX-SMT-S-64-50
    KYCON
    SMD
    SMT MODJACK, RT< 6P4C SHIELD, BL
GDLX-SMT-S-64-50 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GDLX-A-64 Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GDLX Series GDLX A 64 Series Shield Option Positions & Contacts Right Angle Modular Jack Product Features Available in high temp for Reflow compatibility Panel Stops, Shielding and Keying Options Available Snap-In Board Retention Tabs CSA/NRTL Certified File No. LR78160 Performance Specifications Materials and Finish Housing Material PBT Thermoplastic, Glass Filled, UL 94V-0 Rated, Black Color Shield Material Copper Alloy, Nickel Plated Contact Material Phosphor Bronze Electrical Characteristics Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V AC for 1 Minute Contact Resistance 20 milliohms Max. Current Rating 1.5A Voltage Rating 125V DC Plating Option Series GDLX - Right Angle Modular Jack PCB Mount Shield Options A - With Panel Stops, Non-Shielded N - Without Panel Stops, Non-Shielded S - With Panel Stops, Shielded Number of Positions / Contacts 64 - 6 Positions / 4 Contacts 66 - 6 Positions / 6 Contacts 88 - 8 Positions / 8 Contacts Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Contact Kycon for Keyed and other Options GDLX Series Dimensions in mm GDLX-A-64 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0719
GDLX-SMT-S-64-50 价格&库存
很抱歉,暂时无法提供与“GDLX-SMT-S-64-50”相匹配的价格&库存,您可以联系我们找货
GDLX-SMT-S-64-50
  • 2400+10.194502400+1.32055
