GLX-A-64-BLK
GLX-A-64-BLK
    KYCON
    插件
    MODJACK LOW/PROF RT
GLX-A-64-BLK 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GLX-A-44 Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GLX Series Right Angle Modular Jack Product Features 0.570" Height Snap-In Board Retention Tabs Available in 4, 6, 8 and 10 Position Housings CSA/NRTL Certified File No. LR78160 UL File No. E134345 Performance Specifications Materials and Finish Housing Material PBT Thermoplastic, UL 94V-0 Rated Contact Material Phosphor Bronze Electrical Characteristics Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V RMS, 60Hz Contact Resistance 20 milliohms Max. Current Rating 1.5A Voltage Rating 125V DC GLX A 44 Series Shield Option Positions & Contacts Other Option Series GLX - Right Angle Modular Jack Shield Options A - Non-Shielded with Panel Stops N - Non-Shielded without Panel Stops Number of Positions / Contacts 44 - 4 Positions / 4 Contacts 64 - 6 Positions / 4 Contacts 66 - 6 Positions / 6 Contacts Other Option Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Color Option Blank - Gray BLK - Black Contact Kycon for High Temperature and Other Options GLX Series Dimensions in mm GLX-A-44xx Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0621
GLX-A-64-BLK 价格&库存
很抱歉,暂时无法提供与“GLX-A-64-BLK”相匹配的价格&库存,您可以联系我们找货
