GWLX-N-88-G/R
GWLX-N-88-G/R
    KYCON
    8P8C MOD JACK, UNSHIELD, W/GREEN
GWLX-N-88-G/R 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GWLX-N-88-G/G Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GWLX N 88 G/G Series Shield Option No. of Positions & Contacts LED Color Option GWLX Series Right Angle Modular Jack with LED, Tab Up Product Features Series GWLX - Modular Jack with LED, Through Hole Easy Viewing LEDs to Act as Power/Transmit Indicators Snap-In Retention Tabs Available Fully Shielded for EMI/RFI Protection Available Through Hole and Surface Mount CSA/NRTL Certified File No. LR78160 UL File No. E134345 Shield Option N - Non-Shielded S - Fully Shielded S2 - Fully Shielded with Side Ground Tabs S9 - Shielded with Top & Side Tabs Performance Specifications Number of Positions/Contacts 88 - 8 Positions / 8 Contacts Materials and Finish Housing Housing Material High Temperature Thermoplastic Shield Material Copper Alloy, Nickel Plated Contact Material Phosphor Bronze Electrical Characteristics Insulation Resistance 500 Megohms Min. Contact Resistance 20 milliohms Max. Current Rating 1.5A Voltage Rating 125V DC Operating Temperature -40°C to +85°C Durability Rating 500 Mating Cycles Min. Plating Option LED Color G/G - Left: Green, Right: Green Y/Y - Left: Yellow, Right: Yellow Y/G - Left: Yellow, Right: Green G/Y - Left: Green, Right: Yellow G/R - Left: Green, Right: Red Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Contact Kycon for Other Options GWLX Series Dimensions in mm GWLX-N-88-x-x Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
GWLX-N-88-G/R 价格&库存
很抱歉,暂时无法提供与“GWLX-N-88-G/R”相匹配的价格&库存,您可以联系我们找货
GWLX-N-88-G/R
  • 1000+10.040501000+1.25647
