2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
GMX-SMT2-S6-88
Part Number Builder
LR78160
MODULAR JACKS AND PLUGS: GMX-SMT2 Series
Surface Mount Modular Jack
Product Features
Low Profile Design Suitable for PC Add-On
Board Applications
Available in 4, 6, 8, and 10 Position Housings
Available Fully Shielded for EMI/RFI Protection
CSA/NRTL Certified File No. LR78160
UL File No. E134345
Performance Specifications
Materials and Finish
Housing Material
High Temperature Thermoplastic, Reflow Compatible,
UL 94V-0 Rated, Black Color
Shield Material
Copper Alloy, Nickel Plated
Contact Material
Phosphor Bronze
Electrical Characteristics
Insulation Resistance
500 Megohms Min.
Dielectric Withstanding Voltage
1000V RMS, 60Hz
Contact Resistance
20 milliohms Max.
Current Rating
1.0A
Voltage Rating
125V DC
Operating Temperature
-40°C to +85°C
Durability
1000 Mating Cycles Min.
GMX-SMT2
S6
88
Series
Shield
Option
No. of
Positions
& Contacts
Plating
Options
Packaging
Options
Series
GMX-SMT2 - Surface Mount Right Angle Modular Jack with Post
Shield Options
N - Non-Shielded
S - Shielded with Thru Hole Shield Pins
S2 - Shielded with SMT Shield Tabs (only with 66, 88 and 1010)
S6 - Shielded with Top and Side Grounding Tabs,
SMT Shield Pins (Available only with 8 Positions)
S7 - Fully Shielded with Top and Side Grounding Tabs,
Thru Hole Shield (Available only with 8 Positions)
Number of Positions / Contacts
44 - 4 Positions / 4 Contacts (Only N Option )
64 - 6 Positions / 4 Contacts
66 - 6 Positions / 6 Contacts
88 - 8 Positions / 8 Contacts
1010 - 10 Positions / 10 Contacts
Plating Option
Blank - Gold Flash
50 - 50µ" Gold Plating
Packaging Option
Blank - Bulk
TR - Tape & Reel
Contact Kycon for Other Options
GMX-SMT2 Series
Dimensions in mm
GMX-SMT2-N-88
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
很抱歉,暂时无法提供与“GMX-SMT2-N-101050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+28.08000
- 240+11.21040
- 480+10.83240
- 960+10.64880
