KUSBX-AS2N-W
KUSBX-AS2N-W
    KYCON
    插件
    USB连接器 8P 插件 端口数:2 额定电流:1A 额定电压:30V 工作温度:-40℃~+85℃
KUSBX-AS2N-W 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBX-AS1N-B Part Number Builder KUSBX UNIVERSAL SERIAL BUS: KUSBX Series Right Angle USB AS1N Series Type B Insulator Plating Color Option Option Series KUSBX - Right Angle Universal Serial Bus Product Features Through Hole PCB Mount Compatible with Many Computer Peripherals A and B Types Available Supports Hot Plugging Contact Area with Gold Plating UL File No. E134345 Performance Specifications Materials and Finish Insulator PBT Thermoplastic, UL 94V-0 Rated, Black or White Color Contacts Phosphor Bronze Contact Plating Gold on Contact Area Tin on Soldertails, All over Nickel Shell Brass, Nickel Plated Type AS1N - A Type BS1N - B Type AS2N - Stacked A Type Insulator Color Option B - Black W - White Plating Option Blank - Gold Flash 30 - 30µ" Gold Plating Contact Kycon for other options KUSBX-AS1N Dimensions in mm Mechanical Characteristics 13.1 Insertion Force: 3.57kg Max. Extraction Force: 1.02kg Min. Durability: 1500 Mating Cycles Min. 14.0 Electrical Characteristics Rated Voltage: 30V AC Rated Current: 1.5A Contact Resistance: 30 milliohms Max Insulation Resistance: 1000 Megohms Min. Dielectric Withstanding Voltage: 750V AC Operating Temperature: See Drawing 14.5 12.5 POS. 1 5.12 7.1 6.99 POS. 4 2.8 2.50 2.50 10.28 2.0 13.35 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0121 2.71
KUSBX-AS2N-W 价格&库存
很抱歉,暂时无法提供与“KUSBX-AS2N-W”相匹配的价格&库存,您可以联系我们找货
