GWLEX-S9-88-G/Y
GWLEX-S9-88-G/Y
    KYCON
    插件
    MODJACK LOW/PROF RT< 8P8C SHIELD
GWLEX-S9-88-G/Y 数据手册
KYCON, Inc. 305 Digital Drive, Morgan Hill, CA 95037 (408)494-0330 15.95 16.60 Materials and Finish LED 2 LED 1 8 13.20 Housing Material: PBT UL 94V-0 Rated, Color: Black Shield: Copper Alloy, Nickel Plated Contact Material: Phosphor Bronze 3.05 1 3.00 Plating Options: Standard: Nickel Underplating, Gold Flash Plating on Contact Area, Gold Flash on Solder Area 5.29 50 Option: Nickel Underplating, Contact Area Plated with 50u" Gold to Comply with ANSI/TIA-1096-A, Gold Flash on Solder Area 1.78 3.43 13.72 9.14 12 1.78 4.86 8 3.43 1 10 1 9 1.02 2-Ø3.20 2.54 1.78 8 11 Rated Current: 1.5A Rated Voltage: 125V DC Insulation Resistance: 500 Megohms Min. Contact Resistance: 30 milliohms Max. Dielectric Withstanding Voltage: 1000V AC for 1 Minute 9 10 2.78 2-Ø1.60 12 11 Electrical Characteristics 12-Ø0.90 Mechanical Characteristics Durability Rating: 750 Mating Cycles Min. Operating Temperature: -40°C to +85°C 12.70 Recommended PCB Layout (Top View) LED Characteristics Forward DC Current: 20mA Forward Voltage: 1.8V Typical Ordering Information: GWLEX-S9-88-x/x-xx Shield Plating Option: Blank - Gold Flash 8P8C 50 - 50u" Gold Series Available LED Colors: - G/G - G/Y - Y/Y - G/R - Y/G For Other LED Color Options Please contact Kycon LED 1 LED 2 REV. DATE DESCRIPTION REV. BY CHK. BY DRAWN BY DATE A0 A1 03/22/18 05/31/18 New Drawing Release Drawing H. MA G. Serrato C. Furumasu D. Shehan H. MA 02/08/18 UNITS mm GWLEX-S9-88-x/x LED Schematic + LED 1 12 11 LED 2 10 + - 9 Tolerances RoHS COMPLIANT Right Angle Modular Jack, RoHS Compliant Shielded, Grounding Tabs, With LED(s) X.X ± 0.25 X.XX ± 0.15 Unless Stated Otherwise
GWLEX-S9-88-G/Y 价格&库存
很抱歉,暂时无法提供与“GWLEX-S9-88-G/Y”相匹配的价格&库存,您可以联系我们找货
