CX15577_GABRIELLA-45-S
    LEDIL(芬兰)
    LENS CLR 8-15DEG SPOT ADH TAPE
CX15577_GABRIELLA-45-S 数据手册
PRODUCT DATASHEET GABRIELLA-45-S GABRIELLA-45-S ~9° spot beam with holder and installation tape SPECIFICATION: Dimensions Ø 45.0 mm Height 29.1 mm Fastening tape, pin, screw ROHS compliant yes MATERIALS: Component Type Material Colour C15927_GABRIELLA-45-S Single lens PMMA clear CA15928_GABRIELLA-45-HLD-T Assembly PC black Finish ORDERING INFORMATION: Quantities for one set: Single lens 1 Assembly 1 Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/9 PRODUCT DATASHEET GABRIELLA-45-S Component Qty in box MOQ MPQ Box weight (kg) C15927_GABRIELLA-45-S » Box size: 476 x 273 x 292 mm Single lens 405 90 45 11.5 CA15928_GABRIELLA-45-HLD-T » Box size: 476 x 273 x 292 mm Assembly 405 90 45 5.7 Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET GABRIELLA-45-S See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET GABRIELLA-45-S OPTICAL RESULTS (MEASURED): LED XM-L RGBW (XMLDCL HI) FWHM / FWTM 10.0° / 19.0° Efficiency 89 % Peak intensity 20.4 cd/lm LEDs/each optic 1 Light colour RGBW Required components: LED XQ-E HD FWHM / FWTM 11.0° / 21.0° Efficiency 88 % Peak intensity 16.8 cd/lm LEDs/each optic 4 Light colour RGBW Required components: LED LZ4-04MDPB FWHM / FWTM 10.0° / 18.0° Efficiency 91 % Peak intensity 24.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CZ FWHM / FWTM 14.0° / 25.0° Efficiency 89 % Peak intensity 12 cd/lm LEDs/each optic 4 Light colour RGBW Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET GABRIELLA-45-S OPTICAL RESULTS (MEASURED): LED SBM-40-RGBW FWHM / FWTM 10.0° / 18.0° Efficiency 89 % Peak intensity 25 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxE17A FWHM / FWTM 12.0° / 23.0° Efficiency 90 % Peak intensity 15 cd/lm LEDs/each optic 4 Light colour RGBW Required components: LED NVSW219F FWHM / FWTM 10.0° / 17.0° Efficiency 89 % Peak intensity 24.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSTAR Stage (S2WN) FWHM / FWTM 10.0° / 17.0° Efficiency 90 % Peak intensity 25.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET GABRIELLA-45-S OPTICAL RESULTS (MEASURED): LED SPF05F0A FWHM / FWTM 10.0° / 19.0° Efficiency 89 % Peak intensity 21.8 cd/lm LEDs/each optic 1 Light colour RGBW Required components: LED SPF05F0B FWHM / FWTM 10.0° / 18.0° Efficiency 90 % Peak intensity 22.9 cd/lm LEDs/each optic 1 Light colour RGBW Required components: LED SPF05F0C FWHM / FWTM 11.0° / 20.0° Efficiency 89 % Peak intensity 17.4 cd/lm LEDs/each optic 1 Light colour RGBW Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET GABRIELLA-45-S OPTICAL RESULTS (SIMULATED): LED XHP50 FWHM / FWTM 14.0° / 24.0° Efficiency 89 % Peak intensity 13.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 13.0° / 24.0° Efficiency 91 % Peak intensity 14.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70 FWHM / FWTM 18.0° / 29.0° Efficiency 87 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L RGBW (XMLCTW) FWHM / FWTM 12.0° / 24.0° Efficiency 93 % Peak intensity 15.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET GABRIELLA-45-S OPTICAL RESULTS (SIMULATED): LED XP-L HD FWHM / FWTM 8.0° / 21.0° Efficiency 92 % Peak intensity 23.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSTAR Stage (S2WP) FWHM / FWTM 8.0° / 19.0° Efficiency 93 % Peak intensity 28.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET GABRIELLA-45-S GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 09/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
CX15577_GABRIELLA-45-S 价格&库存
很抱歉,暂时无法提供与“CX15577_GABRIELLA-45-S”相匹配的价格&库存,您可以联系我们找货
