F15952_LINNEA-O-B
F15952_LINNEA-O-B
    LEDIL(芬兰)
    LENS CLEAR ELLIPTICAL/OVAL
F15952_LINNEA-O-B 数据手册
PRODUCT DATASHEET F15952_LINNEA-O-B LINNEA-O-B ~35° + 70° oval beam optimized for 0.5 mm metal sheet or profile. Variant made from PC. SPECIFICATION: Dimensions Height 285.0 x 40.0 mm 10.5 mm Fastening ROHS compliant clips yes MATERIALS: Component Type Material Colour LINNEA-O-B Linear lens PC clear Finish ORDERING INFORMATION: Component F15952_LINNEA-O-B » Box size: 398 x 298 x 265 mm Qty in box 153 MOQ 36 MPQ 9 Box weight (kg) 8.0 Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET F15952_LINNEA-O-B See also our general installation guide: www.ledil.com/installation_guide Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET F15952_LINNEA-O-B OPTICAL RESULTS (MEASURED): LED XP-E FWHM / FWTM 90.0 + 35.0° / 138.0 + 86.0° Efficiency 81 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED L-iC-282-827-865-011A FWHM / FWTM 91.0 + 39.0° / 139.0 + 84.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LP-282-840-009A 60/300 FWHM / FWTM 91.0 + 39.0° / 139.0 + 85.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LS-282-840-011A FWHM / FWTM 92.0 + 39.0° / 140.0 + 86.0° Efficiency 82 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET F15952_LINNEA-O-B OPTICAL RESULTS (MEASURED): LED LX-282-840-023A FWHM / FWTM 91.0 + 39.0° / 139.0 + 86.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LinLED 280x24mm 1100lm 830 2C 30V LINNEA-GC G1 FWHM / FWTM 88.0 + 37.0° / 137.0 + 83.0° Efficiency 82 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFSW757H FWHM / FWTM 92.0 + 41.0° / 140.0 + 89.0° Efficiency 85 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFSx757G FWHM / FWTM 87.0 + 38.0° / 140.0 + 85.0° Efficiency 81 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET F15952_LINNEA-O-B OPTICAL RESULTS (MEASURED): LED PL-LIN-IND-Z1 2800 560x24 FWHM / FWTM 91.0 + 39.0° / 140.0 + 94.0° Efficiency 87 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S5 (2 chip) FWHM / FWTM 90.0 + 38.0° / 138.0 + 86.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S5 (Single chip) FWHM / FWTM 91.0 + 38.0° / 139.0 + 88.0° Efficiency 85 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Strip 1ft 1100lm FC HV4 & LV4 FWHM / FWTM 92.0 + 40.0° / 140.0 + 85.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET F15952_LINNEA-O-B OPTICAL RESULTS (MEASURED): LED Fortimo LED Strip 1ft 1100lm FC HV5 & LV5 FWHM / FWTM 89.0 + 38.0° / 140.0 + 92.0° Efficiency 86 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Strip 1ft 650lm FC HV4 & LV4 FWHM / FWTM 93.0 + 40.0° / 140.0 + 85.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo LED Strip 1ft 650lm FC HV5 & LV5 FWHM / FWTM 85.0 + 33.0° / 136.0 + 90.0° Efficiency 85 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LM561B Plus FWHM / FWTM 88.0 + 37.0° / 137.0 + 83.0° Efficiency 82 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET F15952_LINNEA-O-B OPTICAL RESULTS (MEASURED): LED LT-H282C FWHM / FWTM 88.0 + 33.0° / 136.0 + 84.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-H562C FWHM / FWTM 88.0 + 33.0° / 136.0 + 84.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-Q282B FWHM / FWTM 86.0 + 33.0° / 136.0 + 84.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-S282H FWHM / FWTM 87.0 + 33.0° / 136.0 + 84.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET F15952_LINNEA-O-B OPTICAL RESULTS (MEASURED): LED LT-S562H FWHM / FWTM 87.0 + 33.0° / 136.0 + 84.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-V282E FWHM / FWTM 87.0 + 33.0° / 136.0 + 84.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LT-V562E FWHM / FWTM 87.0 + 33.0° / 136.0 + 84.0° Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 3030 FWHM / FWTM 89.0 + 37.0° / 138.0 + 87.0° Efficiency 84 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET F15952_LINNEA-O-B OPTICAL RESULTS (MEASURED): LED LLE G4 24x280mm 1250lm FWHM / FWTM 89.0 + 38.0° / 138.0 + 86.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LLE G4 24x280mm 2000lm ADV FWHM / FWTM 88.0 + 40.0° / 139.0 + 88.0° Efficiency 83 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LLE G4 24x280mm 650lm FWHM / FWTM 90.0 + 39.0° / 138.0 + 87.0° Efficiency 84 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET F15952_LINNEA-O-B GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 14/11/2023 Subject to change without prior notice Published: 07/02/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
F15952_LINNEA-O-B 价格&库存
很抱歉,暂时无法提供与“F15952_LINNEA-O-B”相匹配的价格&库存,您可以联系我们找货
F15952_LINNEA-O-B
  • 1+39.480461+4.93810
  • 30+38.5770130+4.82510
  • 90+34.5115290+4.31660
  • 150+30.17500150+3.77420
库存:36
F15952_LINNEA-O-B
  • 1+36.76476
  • 4+29.44546
  • 11+27.76286
库存:36
F15952_LINNEA-O-B
    • 1+63.639611+7.95986
    • 18+45.2910718+5.66488
    • 108+38.75702108+4.84762
    • 504+34.98891504+4.37631
    • 1008+33.699171008+4.21500
    • 2007+32.615312007+4.07943
    F15952_LINNEA-O-B
      • 153+21.21012153+2.65290
      • 306+21.03263306+2.63070
      • 459+20.85514459+2.60850
      • 612+20.75677612+2.59620
      • 765+20.58891765+2.57520
