F16314_LINNEA-O-END-ML
    LEDIL(芬兰)
    LENS CLEAR SNAP IN
F16314_LINNEA-O-END-ML 数据手册
A B C D F G H E 15 20 4 2.7 1.1 4 Detail B Scale: 5:1 44.7 1.3 Section view A-A Scale: 2:1 Isometric view Scale: 1:1 44.2 B 9.5 3 3 40 10.54 A A 2 2 PART F16314 TYPE MATERIAL COLOR / COATING PC CLEAR MECHANICAL DRAWING 1 PRODUCT Notes PCB or heatsink level. LED location Ensure LED fitting from a product specific 3D model available from www.ledil.com For more details about installation please see LEDiL Installation Guide on www.ledil.com @ A F16314_LINNEA-O-END-ML Plastic moulding general tolerances according to DIN 16901-130 and applies if not otherwise shown in the drawing. Silicone moulding general tolerances according to ISO 3302-1 Class M3 and applies if not otherwise shown in the drawing. SCALE 2:1 FIRST ANGLE PROJECTION: WEIGHT This drawing is the property of LEDiL Oy. It may not be copied or otherwise distributed without prior written permission from LEDiL Oy. A3 7,3 g B SHEET 1/2 A 1 67.8 282 21 A B C D E F G H MIN 9 69.8 MIN 9 131 3 4 4 17 34 3 3 43.8 21 179 3 45.8 Unfolded view Scale: 1:2 LINNEA-END-ML LINNEA 2 LINNEA-END SHEETMETAL 2FT 2 COMPONENTS INDEX 1 2 3 4 PART TYPE MATERIAL LINNEA-END SHEETMETAL 2FT LINNEA PC LINNEA-END-FL PC LINNEA-END-ML PC COLOR / COATING clear clear clear MECHANICAL DRAWING PRODUCT LINNEA-END SHEETMETAL CUT OUT 1 LINNEA-END-FL Isometric view Scale: 1:4 Tolerances if not otherwise shown According to DIN ISO 2768-1 Linear measures: Up to 30mm class M, otherwise class C. According to DIN ISO 2768-2 Form and position: class L SCALE H G 1:2 FIRST ANGLE PROJECTION: WEIGHT - This drawing is the property of LEDiL Oy. It may not be reproduced, copied or communicated without a written agreement with LEDiL Oy. A3 B SHEET 2/2 A 1
F16314_LINNEA-O-END-ML 价格&库存
很抱歉,暂时无法提供与“F16314_LINNEA-O-END-ML”相匹配的价格&库存,您可以联系我们找货
    • 54+9.7574054+1.22043
      • 54+6.6559054+0.83250
      • 162+6.47841162+0.81030
      • 216+6.43404216+0.80475
      • 540+6.30092540+0.78810
      • 810+6.12343810+0.76590
