FN15736_RONDA-WW-B
FN15736_RONDA-WW-B
    LEDIL(芬兰)
    LENS CLR 60-67DEG ASYM TWIST LCK
FN15736_RONDA-WW-B 数据手册
PRODUCT DATASHEET FN15736_RONDA-WW-B RONDA-WW-B ~60° wide beam with holder B compatible with 3rd party connectors from BJB, IDEAL and Stucchi SPECIFICATION: Dimensions Height Ø 69.9 mm 14.6 mm Fastening screw ROHS compliant yes MATERIALS: Component Type Material Colour RONDA-WW Single lens PMMA clear RONDA-HLD-B Holder PC white Finish ORDERING INFORMATION: Component FN15736_RONDA-WW-B » Box size: Qty in box Single lens 420 MOQ MPQ 120 30 Box weight (kg) 0.0 Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/7 PRODUCT DATASHEET FN15736_RONDA-WW-B Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/7 PRODUCT DATASHEET FN15736_RONDA-WW-B See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/7 PRODUCT DATASHEET FN15736_RONDA-WW-B OPTICAL RESULTS (MEASURED): LED V13 Gen7 FWHM / FWTM 67.0° / 108.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2021 LED CLL04x/CLU04x FWHM / FWTM 71.0° / 136.0° Efficiency 85 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2030 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 63.0° / 98.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2131 LED Fortimo SLM L19 + SLM holder FWHM / FWTM 67.0° / 120.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/7 PRODUCT DATASHEET FN15736_RONDA-WW-B OPTICAL RESULTS (SIMULATED): LED H12 FWHM / FWTM 62.0° Efficiency 83 % LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2131 LED V10 Gen7 FWHM / FWTM 66.0° / 95.0° Efficiency 87 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2002CT LED CLL02x/CLU02x (LES10) FWHM / FWTM 60.0° Efficiency 88 % LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2002CT LED CXA/B 15xx FWHM / FWTM 62.0° Efficiency 89 % LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2001CR Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/7 PRODUCT DATASHEET FN15736_RONDA-WW-B OPTICAL RESULTS (SIMULATED): LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 62.0° Efficiency 89 % LEDs/each optic 1 Light colour White Required components: IDEAL: 50-3001CR LED Soleriq S13 FWHM / FWTM 63.0° Efficiency 84 % LEDs/each optic 1 Light colour White Required components: BJB: 47.319.6111 LED Soleriq S13 FWHM / FWTM 63.0° Efficiency 84 % LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8502-G2 LED Mini Zenigata (GW6BM) FWHM / FWTM 62.0° Efficiency 88 % LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2000P Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/7 PRODUCT DATASHEET FN15736_RONDA-WW-B GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 03/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/7
FN15736_RONDA-WW-B 价格&库存
很抱歉,暂时无法提供与“FN15736_RONDA-WW-B”相匹配的价格&库存,您可以联系我们找货
