CS16577_STRADELLA-IP-28-VSM
    LEDIL(芬兰)
    LENS CLR 138/144DEG FLOOD SCREW
CS16577_STRADELLA-IP-28-VSM 数据手册
PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM STRADELLA-IP-28-VSM IESNA Type V (square) beam for wide areas lighting such as car parks. Variant made from PMMA. SPECIFICATION: Dimensions Height Fastening Ingress protection classes ROHS compliant 100.0 x 100.0 mm 9.5 mm screw IP66, IP67 yes MATERIALS: Component Type Material Colour STRADELLA-IP-28-VSM Multi-lens PMMA clear STRADELLA-28-SEAL Seal Silicone white Finish ORDERING INFORMATION: Component CS16577_STRADELLA-IP-28-VSM » Box size: 476 x 273 x 247 mm Qty in box Multi-lens 156 MOQ MPQ 78 78 Box weight (kg) 6.0 Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM See also our general installation guide: www.ledil.com/installation_guide Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (MEASURED): LED HiQLED STR28 CR JE2835 4x7 xxx FWHM / FWTM 129.0° / 140.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiQLED STR28 CR JK3030 4x7 xxx FWHM / FWTM 128.0° / 137.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED QUICK FLUX STR28 XD2x14 xxx G8 FWHM / FWTM 141.0° / 148.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED QUICK FLUX STR28 XP2x14 xxx G7 FWHM / FWTM 146.0° / 159.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (MEASURED): LED QUICK FLUX STR28 XT2x14 xxx G5 FWHM / FWTM 146.0° / 157.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 2835 FWHM / FWTM 129.0° / 140.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 3030 FWHM / FWTM 138.0° / 148.0° Efficiency 98 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 3030 FWHM / FWTM 128.0° / 137.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (MEASURED): LED XD16 FWHM / FWTM 141.0° / 148.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 146.0° / 159.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 146.0° / 157.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2W585AR FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (MEASURED): LED NF2W585AR FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 153.0° / 161.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW319B FWHM / FWTM 154.0° / 166.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S5 (Single chip) FWHM / FWTM 138.0° / 146.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (MEASURED): LED OSCONIQ S 3030 (QSLR31) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 144.0° / 151.0° Efficiency 96 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM SC28 (LH181B) FWHM / FWTM 125.0° / 134.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM SM28 (LM301B) FWHM / FWTM 129.0° / 142.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (MEASURED): LED Z5M3 FWHM / FWTM 147.0° / 162.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (SIMULATED): LED XP-E2 FWHM / FWTM 130.0° / 137.0° Efficiency 95 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON V2 FWHM / FWTM 150.0° / 158.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757G FWHM / FWTM 144.0° / 155.0° Efficiency 93 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ C 2424 FWHM / FWTM 142.0° / 150.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (SIMULATED): LED OSCONIQ C 3030 FWHM / FWTM 142.0° / 152.0° Efficiency 95 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3030 FWHM / FWTM 146.0° / 156.0° Efficiency 95 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH181B FWHM / FWTM 140.0° / 148.0° Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351B FWHM / FWTM 151.0° / 162.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM OPTICAL RESULTS (SIMULATED): LED SEOUL DC 3030C FWHM / FWTM 146.0° / 156.0° Efficiency 95 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M1/Z5M2 FWHM / FWTM 147.0° / 158.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y19 FWHM / FWTM 138.0° / 148.0° Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22 FWHM / FWTM 140.0° / 148.0° Efficiency 92 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/12 PRODUCT DATASHEET CS16577_STRADELLA-IP-28-VSM GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 22/12/2023 Subject to change without prior notice Published: 23/07/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/12
CS16577_STRADELLA-IP-28-VSM 价格&库存
很抱歉,暂时无法提供与“CS16577_STRADELLA-IP-28-VSM”相匹配的价格&库存,您可以联系我们找货
库存:78
  • 78+56.3151778+7.28437
