LLC610D324-005
LLC610D324-005
    SSTSENSING
    LIQUID LEVEL SENSOR
LLC610D324-005 数据手册
DATA SHEET Liquid Level Switches Optomax Industrial Series FEATURES  Liquid level switches that can detect almost any liquid type; oil or water based   Choice of material; Polysulfone (standard) or Trogamid® Choice of threads Housing/ Mounting    Output Type / Logic Supply Voltage Output Current BENEFITS OUTPUT VALUES High power Output Voltage3 (Vout): Vs = 4.5—15.4VDC Output High Output Low lout = 1A Output Voltage (Vout): Vs = 8—30VDC Output High Output Low lout = 1A Industrial supply voltage Direct load drive design TECHNICAL SPECIFICATIONS Supply voltage (Vs) or Supply current (ls) or Output sink and source current (lout) 4.5VDC to 15.4VDC 8VDC to 30VDC 2.5mA max. (Vs = 15.4VDC) 7.5mA max. (Vs = 30VDC) 1A Operating temperatures Standard: -25°C to +80°C Extended: -40°C to +125°C Storage temperatures Standard: -30°C to +85°C Extended: -40°C to +125°C Housing material 1, 2 Sensor termination Polysulfone or Trogamid® 20AWG, 250mm PTFE wires, 8mm tinned 1) NOTES 2) 3) Temp Vout = Vs - 1.5V max Vout = 0V + 0.5V max Vout = Vs - 1.8V max Vout = 0V + 0.7V max Other sensor options available on request, email: technical@sstsensing.com Need help? Ask the expert Tel: + 44 (0)1236 459 020 and ask for “Technical” Above +85°C, Trogamid is suitable for water based liquids. Oil based liquids can cause deformation of the sensing tip and must be tested for compatibility. Before use check that the fluid in which you wish to use these devices is compatible either with Polysulfone or Trogamid®. Voltages applicable to output value stated. OUTLINE DRAWING HOUSING SPECIFICATIONS All dimensions shown in mm. Tolerances = ±1mm. Housing Series LLx2x0 Series Thread 2x0 6x0 7x0 M12x1x8g with hex nut1 1/2” SAE with O-ring1 1/4” NPT2 Pressure3 7 bar /101 psi maximum Tightening Torque 1.5 Nm / 13.26 in-lbs maximum LLx6x0 Series ELECTRICAL INTERFACE LLx7x0 Series NOTES 1) 2) 3) Hex nut and O-ring sold separately; email: technical@sstsensing.com for details. NPT version can be sealed with PTFE tape. When correctly sealed. Wire Designation Red Vs Green Output Blue 0V CIRCUIT DIAGRAMS In order to suit any application, these sensors have been designed with various output circuit configurations. They are identified by the 3-digit code at the end of the part number as shown in Order Information. CAUTION: Take care when connecting loads. The minimum load impedance should not exceed Vs/max output current. Note: Shorting the output to Vs or 0V will result in irreparable damage to the sensor. ORDER INFORMATION Generate your specific part number using the convention shown below. Use only those letters and numbers that correspond to the sensor and output options you require — omit those you do not. L L X X X 0 D 3 X X X - X X X Housing Material Housing Type Operating Temp. Output Logic Supply Voltage Output Type C Polysulfone 2 2x0 series M12x1 0 -25 °C to +80°C L Output Low in air 24 8-30VDC 001 N-Type with flyback T Trogamid® 6 6x0 series 1/2” SAE 1 -40 °C to +125°C Blank Output High in air Blank 4.5-15.4VDC 002 N-Type with 10kΩ pull-up 7 7x0 series 1/4” NPT 003 N-Type 004 P-Type 005 N&P Push Pull CAUTION INFORMATION Do not exceed maximum ratings and ensure sensor(s) are operated in accordance with their requirements. Carefully follow all wiring instructions. Incorrect wiring can cause permanent damage to the device. SST Sensing Ltd recommend using alcohol based cleaning agents. Do NOT use chlorinated solvents such as trichloroethane as these are likely to attack the sensor material. Failure to comply with these instructions may result in product damage. As customer applications are outside of SST Sensing Ltd.’s control, the information provided is given without legal responsibility. Customers should test under their own conditions to ensure that the equipment is suitable for their intended application. Before use, check that the fluid in which you wish to use these devices is compatible with Polysulfone or Trogamid®. For technical assistance or advice, please email: technical@sstsensing.com General Note: SST Sensing Ltd. reserves the right to make changes to product specifications without notice or liability. All information is subject to SST Sensing Ltd.'s own data and considered accurate at time of going to print. DS-0034 REV 13 © 2017 SST SENSING LTD. 5 H A GMI LL C RES CEN T, S HAWH EAD I ND US TR IAL ES TA TE , CO AT BR ID GE, U K M L5 4 NS w w w.ssts ensi ng .com | e: sal es@ss tse nsin g.co m | t : + 44 ( 0 )12 36 4 5902 0 | f: +4 4 (0 ) 123 6 459 02 6
LLC610D324-005 价格&库存
很抱歉,暂时无法提供与“LLC610D324-005”相匹配的价格&库存,您可以联系我们找货
