B112-002-R
B112-002-R
    TRIPPLITE
    VGA/SVGA VIDEO SWITCH 2-PORT
B112-002-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port Manual VGA/SVGA Video Switch (3x HD15F) MODEL NUMBER: B112-002-R Highlights ● 2-port HD15 VGA/SVGA PushButton Switch ● Rugged Metal Case System Requirements ● Computer with an HD15 port ● VGA or SVGA monitor with HD15M cable Package Includes ● Description This 2-Port Manual VGA/SVGA Switch is the optimal solution for connecting two computers to one monitor or two monitors to one computer. The 2-Port Manual VGA/SVGA Switch features a fully shielded rugged metal case with front-panel push-button switching. Interior printed circuit board design allows for crystal clear resolutions up to 1600 x 1280. It does not require any AC power to operate. Features ● Connects two computers to one monitor or two monitors to one computer ● Fully-shielded rugged metal case with front-panel push button switch ● Does not require external power, software, or complicated set-up procedures Specifications OVERVIEW UPC Code 037332014269 Technology VGA/SVGA VIDEO Max Supported Video Resolution 1920 x 1080 @ 60Hz HDR Support No INPUT Bus Powered Yes Product Length (in.) 4.41 1/3 B112-002-R Manual VGA/SVGA 2 Position Switch 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Length (ft.) 0.37 POWER Power Consumption (Watts) 0.5 PHYSICAL Color Silver Material of Construction Aluminum Rackmountable No Shipping Dimensions (hwd / in.) 4.53 x 1.06 x 3.27 Shipping Dimensions (hwd / cm) 11.51 x 2.69 x 8.31 Shipping Weight (lbs.) 3.53 Shipping Weight (kg) 1.60 Unit Dimensions (hwd / in.) 0.940 x 4.400 x 2.700 Unit Packaging Type Box Unit Weight (lbs.) 0.33 Unit Weight (kg) 0.15 ENVIRONMENTAL Operating Temperature Range 14° to 131°F (-10° to 55°C) Storage Temperature Range 5° to 131°F (-15° to 55°C) Relative Humidity 5% to 90% RH, Non-Condensing BTUs 1.7 BTU/Hr COMMUNICATIONS EDID Compatible Yes IR Remote Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) HD15 (FEMALE) Side B - Connector 1 HD15 (FEMALE) Connector Plating Nickel Input x Output 2x1 FEATURES & SPECIFICATIONS Port Selection Pushbutton 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B112-002-R 价格&库存
很抱歉,暂时无法提供与“B112-002-R”相匹配的价格&库存,您可以联系我们找货
