1000 Eaton Boulevard
Cleveland, OH 44122
United States
BC Personal 120V 450VA 280W Standby UPS,
Tower, USB port, 3 Outlets
Highlights
450VA tower 120V standby UPS
Maintains AC output during
power failures
USB port, Status LEDs
NEMA 5-15P input plug and 3
NEMA 5-15R outlets
MODEL NUMBER: BCPERS450
Package Includes
Description
Tripp Lite's BCPERS450 standby UPS offers AC surge suppression and long lasting battery support for
desktop PCs, network workstations and a wide variety of consumer and professional electronics.
Uninterruptible Power Supply / UPS circuits switch to battery backup mode within milliseconds to keep
connected equipment running without interruption or data loss during power failures, brownouts and
overvoltages. AC surge suppression prevents connected equipment damage. USB communications port
supports built-in power management and auto-shutdown features of Windows and Mac OS X or full
featured monitoring and data-saving auto-shutdown options using Tripp Lite's free PowerAlert monitoring
software.
Features
BCPERS450 small tower 120V standby UPS offers AC power protection from blackouts, brownouts,
overvoltages and transient surges
450VA / 280 watt UPS output capacity
Uninterruptible Power Supply / UPS operation maintains battery-derived AC output during blackouts,
brownouts and overvoltages to prevent data loss and system downtime for connected equipment
Built-in USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
HID-compliant USB port also enables integration with built-in power management and auto shutdown
4.6 minutes runtime at 100% load (280 watts), 15 minutes runtime at 50% load (140 watts)
30 minutes runtime for a desktop computer system consuming 80 watts continuous
3 built-in NEMA 5-15R UPS supported outlets
NEMA 5-15P input connection with 6ft / 1.8m line cord
Network grade AC surge protection is available from all outlets
Supports Tripp Lite's Watchdog system service to restore operation to locked equipment through soft
reboot of application/OS or hard power off/on reboot of connected equipment, ideal for unattended kiosk
applications
1/5
BCPERS450 UPS System
Instruction manual
Cleveland, OH 44122
United States
Front panel LEDs indicate line / battery mode and battery replace status; Audible alarm with alarm
cancel / self-test button
Hot swappable user battery replacement
Optional PDUB15 bypass PDU enable hot-swappable UPS replacement with no disruption to connected
equipment
Small tower housing supports desk or floor placement
Specifications
OVERVIEW
UPC Code
037332033116
UPS Type
Standby
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
3.1A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
450
Output Capacity (Watts)
280
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Battery
Mode)
+/- 5%
Hot-Swap PDU options
PDUB15 (2U / 8 5-15R outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(3) 5-15R
Individually Controllable Load Banks
No
BATTERY
2/5
Cleveland, OH 44122
United States
Runtime Full Load (min.)
4.6 min. (280w)
Runtime Half Load (min.)
15 min. (140w)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 3.6 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
3 LEDs indicate line power, battery power and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
252
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
178
Primary UPS Height (mm)
216
Primary UPS Width (mm)
132
Shipping Dimensions (hwd / in.)
12.20 x 8.10 x 9.60
Shipping Dimensions (hwd / cm)
30.99 x 20.57 x 24.38
Shipping Weight (lbs.)
13.00
Shipping Weight (kg)
5.90
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
21.59 x 13.21 x 17.78
3/5
Cleveland, OH 44122
United States
(hwd, in.)
8.5 x 5.2 x 7
UPS Power Module Weight (kg)
5.44
UPS Power Module Weight (lbs.)
12
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
68
AC Mode Efficiency Rating (100%
Load)
94%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cable is user supplied
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network UPS Tools (NUT)
Compatibility
NUT compatible. See the full list of Tripp Lite NUT compatible UPS systems at
https://www.networkupstools.org/stable-hcl.html?manufacturer=Tripp Lite
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
99V (adjustable to 83V via potentiometer)
High Voltage Transfer to Battery
Power (Setpoint)
176 (adjustable to 147 via potentiometer)
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Hot swappable batteries
APPLICATIONS
UPS Applications
Computer/Peripherals
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$100,000 Ultimate Lifetime
Insurance
4/5
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“BC PERS450”相匹配的价格&库存,您可以联系我们找货
