ISOTEL4 ULTRA
ISOTEL4 ULTRA
    TRIPPLITE
    SURGE SUPPR 4OUT 6'CORD W/RJ11
ISOTEL4 ULTRA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Isobar 4-Outlet Surge Protector, 6 ft. Cord with Right-Angle Plug, 3300 Joules, Diagnostic LEDs, Tel/Fax/Modem, Metal MODEL NUMBER: ISOTEL4ULTRA Highlights ● 4 NEMA 5-15R outlets in exclusive isolated filter banks ● Network-grade 3300-joule surge protection rating ● Durable metal housing designed for tough environments ● Fax/telephone line/modem surge protection ● 6 ft. AC power cord with NEMA 5-15P plug Package Includes Premium protection for A/V home theater components and computer peripherals against dangerous power surges, spikes and line noise. Recommended for homes and home offices. Description Premium protection for your expensive electronics, network hardware and peripherals, the ISOTEL4ULTRA Isobar® 4-Outlet Surge Protector features a network-grade surge protection rating of 3300 joules to defend your sensitive electronics against even the strongest surges and spikes. The ISOTEL4ULTRA features four NEMA 5-15R outlets, which are arranged in two exclusive isolated filter banks that prevent equipment connected to one bank from interacting with equipment connected to the other. These internal barriers also prevent disruptive line noise from causing A/V distortion, computer lockups, data errors and similar problems. Large toroidal chokes, ferrite rod-core inductors, HF/VHF capacitors and multiple layers of metal oxide varistors remove EMI/RFI interference and prevent system crashes, reboots and performance problems. A pair of RJ11 jacks also provides single phone line protection for modems, fax machines and cordless phones. Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the ISOTEL4ULTRA protects all three, covering two protection modes: full normal mode (H-N) and common mode (N-G/H-G). Included safety covers protect against dust while blocking accidental contact with unused outlets. An integrated 12A circuit breaker protects all outlets and shuts down connected equipment in the event of an overload. A lighted on/off switch provides one-touch control over connected components. Diagnostic LEDs show power, protection and line fault status at a glance. A six-foot (1.8-meter) power cord with right-angle 5-15P plug reaches nearby outlets and allows furniture to be placed flush against the wall. Features Network-Grade 3300-Joule Surge Protection for Your Home or Office ElectronicsProtects your A/V components, network hardware, retail displays, appliances, power tools and other expensive electronics against even the strongest surges and spikesRecommended for network workstations, telecom systems, point-of-sale equipment and A/V systems requiring AC line protectionFull normal mode (H-N) and common mode (N-G/H-G) line surge suppressionExceeds IEEE 587 Category A and B surge suppression specificationsRJ11 jacks protect fax, phone and modem signals 4 Outlets Accept Wide Range of Electronic Devices4 NEMA 5-15R AC outlets accept most computer equipment, electronics and appliancesOutlets accommodate up to 2 bulky transformers without blocking other outletsIncluded safety covers block accidental contact with unused outlets Isolated Filter Banks Provide Extra ProtectionOutlets arranged in 2 exclusive isolated filter banks to 1/4 ● ISOTEL4ULTRA Isobar 4-Outlet Surge Protector, Tel/Fax/Modem, Metal Housing ● RJ11 telephone cable ● (4) Outlet safety covers ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States limit noise interaction among connected equipmentBlock disruptive EMI/RFI line noise up to 80 dB that can cause equipment damage or data lossCombine large toroidal chokes, ferrite rod-core inductors, HF/VHF capacitors and metal oxide varistors to block interference Premium Safety FeaturesLighted on/off switch provides one-touch control over connected equipmentAutomatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is requiredDiagnostic LEDs confirm power, protection and line fault status at a glanceConforms to current UL 1449 3rd Edition safety standards Fits Effortlessly Into Your Setup6 ft. AC power cord reaches nearby outletsSpace-saving right-angle NEMA 5-15P plug allows furniture and equipment to move flush against the wallKeyhole slots on bottom panel provide convenient wall or desk mounting optionsMetal housing designed for long life Backed by Ultimate Lifetime Insurance$50,000 Ultimate Lifetime Insurance covers any connected components damaged by power surge (U.S., Canada and Puerto Rico only) Specifications OVERVIEW UPC Code 037332010582 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 135000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 6 Right-Angle Plug Yes Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (4) 5-15R Circuit Breaker (amps) 12 Transformer Accommodation (2) Yes Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Diagnostic LED(s) Yes Switches Combination AC circuit breaker and two position red illuminated on/off power switch Diagnostic LED Details PROTECTION PRESENT (green), LINE FAULT (red) and LINE OK (green) SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 3330 AC Suppression Response Time NM = 0 ns. CM =
ISOTEL4 ULTRA 价格&库存
很抱歉,暂时无法提供与“ISOTEL4 ULTRA”相匹配的价格&库存,您可以联系我们找货
