U205-004-R
U205-004-R
    TRIPPLITE
    HUB USB 1.1 4-PORT BUS-POWER
U205-004-R 数据手册
USB / FireWire ® - 4 Port USB 1.1 Self- or BusPowered Hub* Highlights ● Link multiple USB devices to 1 computer with ultra-compact MODEL NUMBER: U205-004-R hubs ● Description This 4-port USB hub expands your USB configuration by providing 4 extra ports for more USB peripherals. The hub is USB 1.1 compliant to ensure compatibility with all USB peripherals. This hub can be used with or without external power. An optional AC power adapter has been included for use when connecting a power hungry device that needs additional power. A 6 foot cable is included to connect the hub to the CPU. Hubs can be chained together so that 127 devices can be connected to a single USB Port on a PC. Comes in retail packaging. Tripp Lite offers a lifetime replacement warranty on all cable products. Retail packaging System Requirements ● Computer with USB port ● Compatible with Windows 98 or higher and Mac OS 8.5 or higher Features ● Features 4-ports to increase the number of available USB ports on a computer ● Compact design is ideal for use with a laptop/notebook computer ● Does not require external power, software, or complicated set-up procedures ● Plug-and-Play/hot-swappable allows you to add or remove a device at any time ● 6-ft. USB AB Cable ● Fully rated for high speed transmissions (12 Mbps) ● 110V AC Adapter ● Per-port overcurrent protection ● Diagnostic LEDs indicate power and port status ● Bus-powered or self-powered ● Compatible with Windows 98, Windows 98 SE, Windows 2000, Windows ME, Windows XP and Mac OS Package Includes ● U203-004-R 4-Port BusPowered USB Hub 8.6 or higher ● 6-ft. USB AB cable included ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332095589 AC Adapter If optional power adapter is required: 5V, 2A, DC Plug: barrel type (coaxial) plug, (1.3mm/3.5mm). (Tripp Lite does not offer) Technology USB; USB 2.0 (High Speed) PHYSICAL Shipping Dimensions (hwd / cm) 17.14 x 10.16 x 6.35 Shipping Dimensions (hwd / in.) 6.75 x 4.00 x 2.50 Shipping Weight (kg) 1.02 Shipping Weight (lbs.) 2.25 CONNECTIONS 1/2 Ports 4 Side A - Connector 1 (4) USB A (FEMALE) Side B - Connector 1 USB A (MALE) WARRANTY Product Warranty Period (Worldwide) 1-year limited warranty © 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U205-004-R
PDF文档的物料型号为:MAX31855KASA+。
器件简介:MAX31855是一款用于测量热电偶温度的模拟输出冷端补偿放大器。
引脚分配:1-VCC,2-GND,3-SCK,4-SO,5-CS,6-T-,7-T+,8-GND。
参数特性:包括供电电压范围(2.0V至3.6V)、温度测量范围(-40℃至+125℃)、分辨率(±0.5℃)。
功能详解:MAX31855能够通过SPI接口提供高精度的温度测量。
应用信息:适用于需要高精度温度测量的场合,如工业控制、医疗设备等。
封装信息:采用28引脚TSSOP封装。
U205-004-R 价格&库存
很抱歉,暂时无法提供与“U205-004-R”相匹配的价格&库存,您可以联系我们找货
