U225-004-R
U225-004-R
    TRIPPLITE
    HUB USB 4 PORT W/6 CABLE
U225-004-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port USB 2.0 Hub Highlights ● Supports Hi-Speed data transfer rates up to 480 Mbps ● Meets or Exceeds USB 2.0 Specifications ● Supports USB 2.0 spec up to 500mA per port ● Hot Pluggable ● Includes 4ft USB 2.0 Computer to Hub cable MODEL NUMBER: U225-004-R System Requirements ● A Windows, Mac or Linux computer with an available USB port Package Includes Description The U225-004-R 4-port USB 2.0 Hub allows you to attach multiple USB devices to a single USB port on your computer. The hub supports all three data transfer speeds: low speed (1.5 Mbps), full speed (12 Mbps) and Hi-Speed (480 Mbps). Includes four-foot USB 2.0 Computer to Hub cable (A-B). Features ● USB 2.0 and 1.1 compliant ● Compact desktop design ( 4"W x 2.5"D x .625"H ) ● Does not require external power, software, or complicated set-up procedures ● Supports USB 2.0 spec up to 500mA per port ● On bus-power, 500mA from the USB 2.0 computer port is shared between the hub ports ● Plug & Play and Hot Swap capability ● Compatible with Windows, Mac and Linux Specifications OVERVIEW UPC Code 037332116505 Product Type Hub Technology USB 2.0 (High Speed) Host Connector USB A (MALE) VIDEO Number of Monitors Supported 0 Extended Mode No 1/3 ● U225-004-R ● 4ft USB Mini-B 5-Pin Male to USB A Male device cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Mirror Mode No DATA Data Ports (4) USB A (FEMALE) Data Ports Details (4) USB-A - USB 2.0 INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered Yes POWER Power Source Type USB PHYSICAL Color Black; Silver Material of Construction PVC Shipping Dimensions (hwd / in.) 5.00 x 2.00 x 5.20 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Clamshell Unit Weight (lbs.) 0.24 Unit Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 14° to 131°F (-10° to 55°C) Relative Humidity 5% to 90% RH, Non-Condensing BTUs 51.2 BTU/Hr Power Provided to Connected Device(s) 5V 0.5A (2.5W) Output per USB port CONNECTIONS Number of Ports 4 Side A - Connector 1 USB MINI-B 5-PIN (FEMALE) Side B - Connector 1 (4) USB A (FEMALE) FEATURES & SPECIFICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Over Current Protection Yes USB Hub Ports Yes Number of USB Hub Ports 4 USB Specification USB 2.0 (up to 480 Mbps) Driver Required No STANDARDS & COMPLIANCE TAA Compliant Option N Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U225-004-R 价格&库存
很抱歉,暂时无法提供与“U225-004-R”相匹配的价格&库存,您可以联系我们找货
