188
188
    ADAFRUIT
    GRAPHIC KS0108 LCD 128X64 + EXTR
188 数据手册
LCD-128H064A Vishay 128 x 64 Graphic LCD FEATURES • Type: Graphic • Display format: 128 x 64 dots • Built-in controller: Samsung KS 0107/KS 0108 (or equivalent) • Duty cycle: 1/64 • + 5 V power supply • N.V. built-in • Compliant to RoHS directive 2002/95/EC MECHANICAL DATA ITEM ABSOLUTE MAXIMUM RATINGS STANDARD VALUE Module Dimension 93.0 x 70.0 Viewing Area 72.0 x 40.0 Dot Size 0.48 x 0.48 Dot Pitch 0.52 x 0.52 Mounting Hole 88.0 x 65.0 Character Size N/a UNIT ITEM mm STANDARD VALUE SYMBOL MIN. TYP. MAX. Power Supply VDD to VSS 4.75 5.0 5.25 Input Voltage - 0.3 - VDD VI UNIT V Note • VSS = 0 V, VDD = 5.0 V ELECTRICAL CHARACTERISTICS ITEM SYMBOL Input Voltage Supply Current Recommended LC Driving Voltage for Normal Temperature Version Module LED Forward Current - Edge EL Power Supply Current TYP. MAX. L level 0.7 VDD - VDD VIO H level 0 - 0.3 VDD IDD VDD = + 5 V - 2.5 7.5 VF LED Forward Current - Array MIN. VDD VDD to V0 LED Forward Voltage STANDARD VALUE CONDITION - 20 °C 9.9 10.4 10.9 0 °C 9.7 10.2 10.7 25 °C 8.9 9.4 9.9 50 °C 8.6 9.1 9.6 70 °C 8.4 8.9 9.4 25 °C - 4.2 4.6 - 330 660 - 120 240 - - 5.0 IF 25 °C IEL VEL = 110 VAC, 400 Hz UNIT V mA V V mA mA OPTIONS PROCESS COLOR TN BACKLIGHT STN Gray STN Yellow STN Blue FSTN B&W x x x x STN Color None LED EL x x x CCFL For detailed information, please see the “Product Numbering System” document. Document Number: 37329 Revision: 16-Mar-09 For technical questions, contact: displays@vishay.com www.vishay.com 1 LCD-128H064A 128 x 64 Graphic LCD Vishay INTERFACE PIN FUNCTION PIN NO. SYMBOL FUNCTION 1 VSS Ground 2 VDD Power supply (+ 5 V) 3 V0 Contrast adjustment 4 D/I Data/instruction 5 R/W Data read/write 6 E H → L enable signal 7 DB0 Data bus line 8 DB1 Data bus line 9 DB2 Data bus line 10 DB3 Data bus line 11 DB4 Data bus line 12 DB5 Data bus line 13 DB6 Data bus line 14 DB7 Data bus line 15 CS1 Chip select for IC1 16 CS2 Chip select for IC1 17 RST Reset 18 VEE Negative voltage output 19 A Power supply for LED (+ 4.2 V), RA = 0 Ω 20 K Power supply for LED (0 V) DIMENSIONS in millimeters 0.52 0.48 66.52 (AA) 0.52 0.48 13.24 Dot Size 1.5 13.6 Max. 2.5 72.0 (VA) 29.92 14.0 K 9.7 Max. 5.1 5.08 70.0 ± 0.5 A 9.0 65.0 18.38 33.24 (AA) 80.0 10.5 32.46 9.9 15.0 50.2 40.0 (VA) 93.0 ± 0.5 7.0 4 x Ø 1.0 PTH 20 x Ø 1.0 PTH 1.8 14.0 2.5 www.vishay.com 2 48.26 (P2.54 x 19) 1 2.5 20 4 x Ø 2.5 PTH 4 x Ø 6.5 PAD 1.6 LED B/L 1.6 EL or NO B/L 88.0 For technical questions, contact: displays@vishay.com Document Number: 37329 Revision: 16-Mar-09 Legal Disclaimer Notice www.vishay.com Vishay Disclaimer ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA ARE SUBJECT TO CHANGE WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. Vishay Intertechnology, Inc., its affiliates, agents, and employees, and all persons acting on its or their behalf (collectively, “Vishay”), disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. Vishay makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, Vishay disclaims (i) any and all liability arising out of the application or use of any product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Statements regarding the suitability of products for certain types of applications are based on Vishay's knowledge of typical requirements that are often placed on Vishay products in generic applications. Such statements are not binding statements about the suitability of products for a particular application. It is the customer's responsibility to validate that a particular product with the properties described in the product specification is suitable for use in a particular application. Parameters provided in datasheets and / or specifications may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated for each customer application by the customer's technical experts. Product specifications do not expand or otherwise modify Vishay's terms and conditions of purchase, including but not limited to the warranty expressed therein. Hyperlinks included in this datasheet may direct users to third-party websites. These links are provided as a convenience and for informational purposes only. Inclusion of these hyperlinks does not constitute an endorsement or an approval by Vishay of any of the products, services or opinions of the corporation, organization or individual associated with the third-party website. Vishay disclaims any and all liability and bears no responsibility for the accuracy, legality or content of the third-party website or for that of subsequent links. Except as expressly indicated in writing, Vishay products are not designed for use in medical, life-saving, or life-sustaining applications or for any other application in which the failure of the Vishay product could result in personal injury or death. Customers using or selling Vishay products not expressly indicated for use in such applications do so at their own risk. Please contact authorized Vishay personnel to obtain written terms and conditions regarding products designed for such applications. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of Vishay. Product names and markings noted herein may be trademarks of their respective owners. © 2023 VISHAY INTERTECHNOLOGY, INC. ALL RIGHTS RESERVED Revision: 01-Jan-2023 1 Document Number: 91000
很抱歉,暂时无法提供与“188”相匹配的价格&库存,您可以联系我们找货
