C16-96.000-8-1520-X2-R
    AKER(安碁科技)
    SIP4
    96 MHz ±20ppm 晶体 8pF 4-SMD,无引线
C16-96.000-8-1520-X2-R 数据手册
Aker P/N : C16-96.000-8-1520-X2-R RoHS compliance MSL:Level 1 SMD CRYSTAL SPECIFICATION 1 . ELECTRICAL CHARACTERISTICS Oscillation Mode : Fundamental Cutting Mode : AT CUT Measurement Equipment : 250B(Measured FL) Insulation Resistance : More than 500M ohms at DC 100V Parameters Nominal Frequency Frequency Tolerance Frequency Stability Load Capacitance Aging Operating Temperature Storage Temperature Range Drive Level Equivalent Series Resistance Shunt Capacitance Symbol FL CL DL ESR C0 Electrical Spec Notes Min. Typ. Max. Units. 96.000000 MHz ±15 ppm at 25℃ ± 3℃ ±20 ppm Operating Temp (Refer 25℃) 8 pF ±3 ppm First Year at 25℃ ~ ℃ 105 -40 ~ ℃ 125 -55 200 uW 30 Ω @Series 3 pF 2 . DIMENSION : ( Unit : mm ) < S ID E > 1 .6 ± 0 .15 C eram ic B ase 1.2 ± 0.15 #4 M etal L id #3 A K ER #1 #2 0 .4 M ax. 1 .05 0 .5 #2 #4 #3 0 .5 # 2:G N D #4 :N C 0.6 0.4 0.8 0.3 #1 0 .75 *Please kindly be noted that AKER DO NOT guarantee parts quality which involves human security application.* Aker P/N : C16-96.000-8-1520-X2-R RoHS compliance MSL:Level 1 3 . PACKING : TAPE SPECIFICATION ( Unit : mm ) Feeding 4 . SOLDERING REFLOW PROFILE : Aker P/N : C16-96.000-8-1520-X2-R RoHS compliance MSL:Level 1 5 . MECHANICAL PERFORMANCE TEST ITEMS TEST METHODS AND TEST CONDITION 5.1 Drop Test The specimen is measured for its frequency and resistance before the test. It is then dropped from a hight of 75 cm or more as a free fall object onto a hard wooden plate of 30mm or more in thickness. 5.2 Vibration Test The specimen is measured for its frequency and resistance before the test. Most them into X,Y and Z axes, respectively, for the vibration test. Vibration condition: Frequency range ; 20~2000HZ Peak to peak amplitude : 1.52 mm Peak acceleration : 20G Sweep time : 20 minute / axis Pendicular total test time : 4 hours 5.3 Resistance to Soldering Test The specimen is measured for its frequency and resistance before the test. Place the specimen on the belt of the converynace and let it pass through the reflow with the presetted temperature condition. After passing twice the reflow place,the specimen under the referee condition for -~2 hours and then measure its electrical performance. Temperature Condition of IR Simulation: The temperature range of the preheated section is setted at 150~180℃ for 60~120 sec. For the next section the temperature range is setted at 217~260℃ for 45~90 sec. and within this time range the specimen should be able to sustain at the peak temperature, 260+/-3℃ , for 10 sec long. 5.4 Fine Leak Test Place the specimen in a pressurized container and pressurize it with the detection gas ( mixed gas consisting of 95% or more helium ) for at least 2 hours. Complete the measurement of the concentration of helium within 30 min after taking it out from the pressurized container. The referee condition . Temperature 25 ± 2 ℃ Humidity 44 ~ 55 % Pressure 86 ~ 106 kPa ( in accordance with MIL-STD-883E : 1014. 9 ) PERFORMANCE To satisfy the electrical performance . Less than 1.0 * 10 - 8 atm .c.c. / sec, Helium Aker P/N : C16-96.000-8-1520-X2-R RoHS compliance MSL:Level 1 6 . CLIMATIC RESISTANCE TEST ITEMS 6.1 Low Temp Exposure Test TEST METHODS AND TEST CONDITION The specimen is measured for its frequency and resistance before the test . Place the specimen in the chamber and kept it at the temperature of - 40 ± 3℃ for 168 ± 6 hours . Take the specimen out of the chamber and measure itselectrical performance after leaving 1~2 hours under the referee condition. 6.2 Aging Test The specimen is measured for its frequency and resistance before the test . Place the specimen in the testing chamber and keep it at the temperature of + 125 ± 3℃ for 720 ± 48 hours. And then take the specimen out of the chamber and measure its electrical performance after leaving for 1 ~ 2 hours under the referee condition . 6.3 High Temperature & High Humidty The specimen is measured for its frequency and resistance before the test . Place the specimen in the testing chamber and kept it at the temperature of + 85 ± 5 ℃ and humidity of 85 ± 5 % for 168 ± 6 hours.and then take the specimen out and measure its electrical performance after leaving for 1~2 hours under the referee condition. 6.4 Temperature Cycle Test The specimen is measured for its frequency and resistance before the test . Subject the specimen to the 100 cycles of temperature ranges stated below . High temp . + 125 ± 3 ℃ (15± 3 min). 2~3 min. 2~3 min. Low temp . -55 ±3 ℃ (15± 3 min). Measure its electrical performance after leaving it for 1 ~ 2 hours under the referee condition . PERFORMANCE To satisfy the electrical performance .
C16-96.000-8-1520-X2-R 价格&库存
很抱歉,暂时无法提供与“C16-96.000-8-1520-X2-R”相匹配的价格&库存,您可以联系我们找货
  • 1000+14.224711000+1.84611
  • 2000+13.637982000+1.76996
  • 3000+13.306303000+1.72692
  • 5000+12.900135000+1.67421
库存:850
  • 1+21.665891+2.81184
  • 10+18.8325010+2.44412
  • 25+17.8073625+2.31107
  • 50+17.0711050+2.21552
  • 100+16.36457100+2.12383
  • 250+15.47669250+2.00860
  • 500+14.83717500+1.92560
库存:850
