2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KLDHCX-MM-0202-BTR
Part Number Builder
LR78160
DC POWER CONNECTORS: KLDHCX-MM Series
High Current Mid Mount DC Power Jack
Product Features
2.0mm and 2.5mm
Built-In DC On/Off Switch
High Current, Rated 5A
Good For Low Profile Applications
Shielded
CSA/NRTL Certified File No. LR78160
Performance Specifications
Materials and Finish
Body:
High Temperature Thermoplastic, UL 94V-0, Color Black
Contact #1: Brass, Gold Flash
Contact #2: Phosphor Bronze, Gold Flash
Contact #3: Brass, Gold Flash
KLDHCX-MM-0202
B
TR
Series
Diameter
Packaging
Series
KLDHCX-MM-0202 - High Current Mid Mount DC Power Jack
Diameter
A - 2.0mm Center Pin Diameter
B - 2.5mm Center Pin Diameter
Packaging
TR - Tape and Reel
Contact Kycon For Other Options
KLDHCX-MM Series
Dimensions in mm
Electrical Characteristics
Rated Voltage: 24V RMS
Rated Current: 5A
Contact Resistance:
Between Terminals: 30 milliohms Max.
Plug to Contacts: 50 milliohms Max.
Insulation Resistance: 100 Megohms Min. at 500V DC
Dielectric Withstanding Voltage: 500V for 1 Minute
Mechanical Characteristics
Durability: 5000 Cycles
Insertion Force: 0.3kg - 3.0kg
Extraction Force: 0.3kg -3.0kg
Operating Temperature: -25°C to +70°C
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0118
很抱歉,暂时无法提供与“KLDHCX-MM-0202-ATR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 450+9.39541450+1.21446
- 900+8.94689900+1.15648
- 1350+8.694521350+1.12386
- 2250+8.386872250+1.08410
- 3150+8.190263150+1.05868
- 4500+7.986894500+1.03239
- 国内价格 香港价格
- 1+14.474221+1.87095
- 10+12.2966810+1.58948
- 25+11.5247225+1.48970
- 50+10.9722350+1.41828
- 100+10.44780100+1.35049
