A17157-13
A17157-13
    LAIRD(莱尔德)
    TFLEX HD3130,DC1 18X18IN
A17157-13 数据手册
TflexTM HD300 Series Thermal Gap Filler PRODUCT DESCRIPTION Laird TflexTM HD300 is a 2.7 W/mK gap filler material in Laird’s high deflection line of products. Tflex HD300 is an excellent choice when wide manufacturing tolerances occur as variable gaps can be filled with Tflex HD300 while generating minimal board and component stress. Laird’s unique manufacturing capabilities, and filler and resin knowledge result in this unique product designed with customer applications in mind. Tflex HD300 material exhibits excellent surface wetting characteristics and high deflection properties ensuring low contact resistances and providing an overall lower total thermal resistance. A Tgard™ liner at one side option is provided to form into Tflex HD300TG, offer guaranteed >6KV AC dielectric barrier, is cut-through resistant and enables easy non-tacky handling at one side. A Tgard™ liner in the middle option is provided to form into Tflex HD300MTG for 40mil and above thicknesses, offer guaranteed >6KV AC dielectric barrier, has cut-through resistant and two-sided tackiness. FEATURES AND BENEFITS • • • • • • 2.7 W/m K thermal conductivity Low pressure versus deflection characteristics Excellent surface wetting for low contact resistance Minimizes board and component stress. Large tolerance applications RoHS and REACH compliant SPECIFICATIONS TYPICAL PROPERTIES VALUE TEST METHOD Construction & Composition Color Thickness Range Thickness Tolerance Thermal Conductivity (W/mK) Density (g/cc) Hardness (Shore 00) Outgassing TML (weight %) Outgassing CVCM (weight %) Temperature Range Rth@ 40 mils, 10 psi Dielectric Constant @ 1 MHz UL Flammability Rating Volume Resistivity Ceramic filled silicone sheet Pink 0.50mm (0.020”) 5.0mm (0.20”) +/- 10% 2.7 3.1 38 0.39 0.10 -40°C to 200°C* 0.573°C–in2/W 6.62 V-0 1.2x 1014 N/A Visual N/A N/A ASTM D5470 Helium Pycnometer ASTM D2240 ASTM E595 ASTM E595 Laird Test Method ASTM D5470 (Modified) ASTM D150 UL-94 ASTM D257 *Upper Temperature range for HD300TG, HD300MTG is 180°C. Americas: +1.866.928.8181 Europe: +49.(0).8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com TflexTM HD300 Series Thermal Gap Filler Tflex HD300 Thermal Resistance vs. Pressure 1.200 C-in2/W 1.000 C-in2/W 0.800 C-in2/W 0.600 C-in2/W 0.400 C-in2/W 0.200 C-in2/W 0.000 C-in2/W 10 psi 20 psi 30 psi 40 psi 50 psi 60 psi 70 psi 80 psi 90 psi 100 psi Tflex HD340 Tflex HD360 Tflex HD380 Tflex HD3100 Tflex HD300 Deflection vs Pressure 80% 70% 60% 50% 40% 30% 20% 10% 0% 10psi 20psi 30psi Tflex HD340 40psi 50psi TflexHD360 60psi 70psi TflexHD380 80psi 90psi 100psi TflexHD3100 AVAILABILITY STANDARD THICKNESSES • 0.5mm (0.020”) to 5.0mm (0.200”) thick material available in 0.25mm (0.010”) increments • Available in standard sheet sizes of 18” x 18” and 9” x 9” or custom die cut parts OPTIONS • DC1 – eliminate tack from one side • TG – Tgard liner on top of HD300 • MTG – Tgard liner within HD300 material PART NUMBER SYSTEM Tflex™ indicates Laird elastomeric thermal gap filler product line. HD3xxx indicates Tflex HD300 product line with thickness in mils (0.001”) EXAMPLES: • • • • Tflex HD340 = 0.040” thick Tflex™ HD300 material Tflex HD3100DC1 = 0.10” thick Tflex™ HD300 material with DC1 option Tflex HD360TG – 0.060” thick Tflex HD300 material with Tgard layer on top Tflex HD380MTG – 0.080” thick Tflex HD300 material with Tgard layer in the middle of Tflex HD300 Tflex HD300 DS 091318 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
A17157-13 价格&库存
很抱歉,暂时无法提供与“A17157-13”相匹配的价格&库存,您可以联系我们找货
