TflexTM HD700 Series
Thermal Gap Filler
PRODUCT DESCRIPTION
Laird Tflex™ HD700 Is our latest product in our High Deflection series. Tflex™ HD700 combines 5
W/mK thermal conductivity with superior pressure versus deflection characteristics. The
combination will allow minimal stress on components while also yielding low thermal resistance.
As a result, less mechanical and thermal stresses will be experienced within your device.
Tflex™ HD700 is available in thickness from 0.5mm (0.020”) to 5mm (0.200”). Laird can provide
material to meet your production needs in any region through our local production facilities.
Please contact your local Laird sales or field engineering contact for samples or questions.
FEATURES AND BENEFITS
5.0 W/mK thermal conductivity
Low pressure versus deflection
Excellent surface wetting for low contact resistance
Minimizes board and component stress
Large tolerance applications
Environmentally friendly solution that meets regulatory requirements including RoHS and
REACH
SPECIFICATIONS
TYPICAL PROPERTIES
VALUE
TEST METHOD
Construction & Composition
Color
Thickness Range
Ceramic filled silicone sheet
Pink
0.50mm (0.020”) 5.0mm (0.20”)
N/A
Visual
N/A
Thermal Conductivity (W/mK)
5.0
ASTM D5470
Density (g/cc)
Hardness (Shore 00)
Helium Pycnometer
ASTM D2240
Outgassing TML (weight %)
3.3
66 (0.5-0.75mm)
55 (1-5mm)
0.23
Outgassing CVCM (weight %)
0.07
ASTM E595
Temperature Range
Rth@ 40 mils, 10 psi
-50°C to 200°C
0.287°C–in2/W
Laird Test Method
ASTM D5470 (Modified)
Dielectric Constant @ 1 MHz
5.01
ASTM D150
UL Flammability Rating
V-0
Volume Resistivity
Americas: +1.866.928.8181
Europe: +49.(0).8031.2460.0
Asia: +86.755.2714.1166
www.lairdtech.com
1.4x
ASTM E595
UL 94
1014 ohm-cm
ASTM D257
Thermal Gap Filler
Tflex HD700 Thermal Resistance vs Pressure
1.400 C-in2/W
1.200 C-in2/W
1.000 C-in2/W
0.800 C-in2/W
0.600 C-in2/W
0.400 C-in2/W
0.200 C-in2/W
0.000 C-in2/W
10 psi
20 psi
30 psi
40 psi
50 psi
60 psi
70 psi
80 psi
90 psi 100 psi
Tflex HD720
Tflex HD740
Tflex HD780
Tflex HD7100
Tflex HD7140
Tflex HD7200
Tflex HD700 Deflection vs Pressure
80%
60%
40%
20%
0%
0 psi
5 psi
Tflex HD740
Tflex HD7140
10 psi
15 psi
20 psi
25 psi
Tflex HD780
Tflex HD7180
30 psi
Tflex HD7100
Tflex HD7200
AVAILABILITY
STANDARD THICKNESSES
• 0.5mm (0.020”) to 5.0mm (0.200”) thick material available in 0.25mm (0.010”) increments
• Available in standard sheet sizes of 18” x 18” and 9” x 9” or custom die cut parts
OPTIONS
• DC1 – eliminate tack from one side
PART NUMBER SYSTEM
Tflex™ indicates Laird elastomeric thermal gap filler product line. HD7xxx indicates Tflex HD700 product line with thickness in mils (0.001”)
EXAMPLES:
• Tflex™ HD740 = 0.040” thick Tflex™ HD700 material
• Tflex™ HD7100,DC1 = 0.10” thick Tflex™ HD700 material with DC1 option
A17758-00 Tflex HD700 DS 071017
Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end
user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or
consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2013 Laird Technologies,
Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
很抱歉,暂时无法提供与“A17690-12”相匹配的价格&库存,您可以联系我们找货
