A17653-13
A17653-13
    LAIRD(莱尔德)
    TFLEX HD7130 9X9IN
A17653-13 数据手册
TflexTM HD700 Series Thermal Gap Filler PRODUCT DESCRIPTION Laird Tflex™ HD700 Is our latest product in our High Deflection series. Tflex™ HD700 combines 5 W/mK thermal conductivity with superior pressure versus deflection characteristics. The combination will allow minimal stress on components while also yielding low thermal resistance. As a result, less mechanical and thermal stresses will be experienced within your device. Tflex™ HD700 is available in thickness from 0.5mm (0.020”) to 5mm (0.200”). Laird can provide material to meet your production needs in any region through our local production facilities. Please contact your local Laird sales or field engineering contact for samples or questions. FEATURES AND BENEFITS • • • • • • 5.0 W/mK thermal conductivity Low pressure versus deflection Excellent surface wetting for low contact resistance Minimizes board and component stress Large tolerance applications Environmentally friendly solution that meets regulatory requirements including RoHS and REACH SPECIFICATIONS TYPICAL PROPERTIES VALUE TEST METHOD Construction & Composition Color Thickness Range Ceramic filled silicone sheet Pink 0.50mm (0.020”) 5.0mm (0.20”) N/A Visual N/A Thermal Conductivity (W/mK) 5.0 ASTM D5470 Density (g/cc) Hardness (Shore 00) Helium Pycnometer ASTM D2240 Outgassing TML (weight %) 3.3 66 (0.5-0.75mm) 55 (1-5mm) 0.23 Outgassing CVCM (weight %) 0.07 ASTM E595 Temperature Range Rth@ 40 mils, 10 psi -50°C to 200°C 0.287°C–in2/W Laird Test Method ASTM D5470 (Modified) Dielectric Constant @ 1 MHz 5.01 ASTM D150 UL Flammability Rating V-0 Volume Resistivity Americas: +1.866.928.8181 Europe: +49.(0).8031.2460.0 Asia: +86.755.2714.1166 www.lairdtech.com 1.4x ASTM E595 UL 94 1014 ohm-cm ASTM D257 TflexTM HD700 Series Thermal Gap Filler Tflex HD700 Thermal Resistance vs Pressure 1.400 C-in2/W 1.200 C-in2/W 1.000 C-in2/W 0.800 C-in2/W 0.600 C-in2/W 0.400 C-in2/W 0.200 C-in2/W 0.000 C-in2/W 10 psi 20 psi 30 psi 40 psi 50 psi 60 psi 70 psi 80 psi 90 psi 100 psi Tflex HD720 Tflex HD740 Tflex HD780 Tflex HD7100 Tflex HD7140 Tflex HD7200 Tflex HD700 Deflection vs Pressure 80% 60% 40% 20% 0% 0 psi 5 psi Tflex HD740 Tflex HD7140 10 psi 15 psi 20 psi 25 psi Tflex HD780 Tflex HD7180 30 psi Tflex HD7100 Tflex HD7200 AVAILABILITY STANDARD THICKNESSES • 0.5mm (0.020”) to 5.0mm (0.200”) thick material available in 0.25mm (0.010”) increments • Available in standard sheet sizes of 18” x 18” and 9” x 9” or custom die cut parts OPTIONS • DC1 – eliminate tack from one side PART NUMBER SYSTEM Tflex™ indicates Laird elastomeric thermal gap filler product line. HD7xxx indicates Tflex HD700 product line with thickness in mils (0.001”) EXAMPLES: • Tflex™ HD740 = 0.040” thick Tflex™ HD700 material • Tflex™ HD7100,DC1 = 0.10” thick Tflex™ HD700 material with DC1 option A17758-00 Tflex HD700 DS 071017 Any information furnished by Laird Technologies, Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird Technologies materials rests with the end user. Laird Technologies makes no warranties as to the fitness, merchantability, suitability or non- infringement of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2013 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Technologies Logo, and other marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird Technologies or any third party intellectual property rights.
A17653-13 价格&库存
很抱歉,暂时无法提供与“A17653-13”相匹配的价格&库存,您可以联系我们找货
